Автор Тема: Prognosis H0 model railroad - "The town from the dining room"  (Прочетена 317476 пъти)
  • Публикации: 5632
Re:Prognosis H0 model railroad - "The town from the dining room"
« Отговор #540 -: 02 Юли 2011, 11:40:09 »
 :clapping: :clapping: :clapping:  :good:
prognosis
« Отговор #541 -: 03 Юли 2011, 18:52:36 »
-8 ITB street car
http://trenulete.info/vagonul-de-tramvai-itb-8/
Today we continued powered tractor wagon effective. We developed the most effective for coupling the wagon bogie locomotive mehano ITB. For that I changed some things between bogie so that it properly in place. I tried to give a slightly inclined position to the front of the wagon, as seen in many photos received from Adrian Crenganis in Iasi, which was kind enough to give me the side walls and original designs More photos of car in different positions! We added numerous accessories such as bars, edges bordering the body, superior direction indicators, the roof vents and the central seat of the plate with the number of circulating wagon route. I mounted the motor and dynamically balanced as we weight model. In film you can see how it behaves on Diorama tram from Slobozia. Tomorrow I hope to manage to do pantograph and give a hand to paint model. Bogie and modification follow masks to resemble as much as what is in the ITB wagon wheels.
http://www.youtube.com/watch?v=TJKyX96hdGw
prognosis
« Отговор #542 -: 07 Юли 2011, 08:47:48 »
-9 ITB street car end of the first model
http://trenulete.info/vagonul-de-tramvai-itb-9-finalul-primului-model/
Finally, I managed to complete a dream of youth, is to take tram ITB model, wagon childhood marked me! H0 functional model to support Panic released by the company ... that we processed parts by laser cutting. The model is made entirely of wood, plywood of various thicknesses and sometimes I use forex (comatex) 1 mm thick. On windows I used the windows of houses acetoafan, we bonded over obscure self-adhesive film for car windows. Pantograph is made of galvanized and tin wire of 0.5, and the sole is flat copper wire to the hammer. For lights we used two warm white SMD series, a 1k resistor and a diode bridge. Unfortunately I have not been and condenser!
Follow the marking and correction at the windows and then paint the second tram!
http://www.youtube.com/watch?v=hKxpFAlK05U
prognosis
« Отговор #543 -: 23 Юли 2011, 09:25:36 »
ITB street car - gasket 2
http://trenulete.info/vagonul-de-tramvai-itb-garnitura-2/
I started working on fitting no. 2 tram classic ITB. This seal will include a tractor trailer model Bucharest and two cars the same type, with three windows plus glass panel on the middle window. And this model is made of wood, plywood namely lime, in various thicknesses from 1 mm wall at 2mm and resp. 3 mm various chassis components. All parts are laser cut by ........, after models made by me in Corel Draw.
Traction model is made using a 12 volt motor bogie locomotive that drives a Mehano. Pantograph is home made from galvanized wire of 0.5 diameter. Ceiling, multi-layer is polished manually! Ballast is made of pieces of lead from the Linotype printing, machine harvest ancient texts!
prognosis
« Отговор #544 -: 29 Юли 2011, 08:09:50 »
ITB street car - gasket 2 to final
http://trenulete.info/vagonul-de-tramvai-itb-% E2% 80% 93-seal-2-to-final /
I fulfilled another dream. One of my childhood to see trams running on the diorama from Slobozia. Perhaps these models are not made as would come from a factory gate, molded plastic, but my designs are functional, I'm proud of them.
The inspiration was a tram all of Iasi, slightly modified so that the middle window has sections for ventilation, the variant that I am adopted. We chose as a model of Iasi wagons, so that I wanted to thank my colleagues from Iasi, Adrian Crenganis modellers, who inspired me and helped me with the initial plans and numerous side pictures of the car!
We chose to work with wood, plywood precisely because wood is a living material, with the power of expression, shape and strength. Do not forget that the first models of trams had more wood in composition! Besides, wood glue and paint is compatible with acrylic material that gives you strength. Wood is very easy to be processed by grinding, much-needed operation for this wagon, where the roof is hard to OptIn rounder with plastic polish.
I turned to trams are a passion for inner, older than the trains, and that we finally found the solution of such a car motoring. I'll probably continue with V09 or other model in this series, because this car is as classic and beautiful car that I will achieve by the same methods as those used for the two sets ITB. I hope the models tram made me to be useful to those who love trams and will hold one of their diorama!
http://www.youtube.com/watch?v=crdhPRqWoH4
prognosis
« Отговор #545 -: 07 Август 2011, 09:27:37 »
Tram Class V 09
http://trenulete.info/tramvaiul-clasic-v-09/
Trams of this type have been made ​​since 1927 in the Central Workshops of the Society of Transport Bucharest.
Corel project I worked on installing the necessary changes with a motorized bogie that I do and as was priginalul trick. We used various wood materials, plywood respectively from 1 mm to 3 mm thick. As shown in the pictures, I already installed the two coaches boxes, the tractor and trailer, after drying glue grouted and tomorrow I will be obedient to dryness.
With this model I will complete my collection of classic trams, for which we have already made ​​a passion!
prognosis
« Отговор #546 -: 09 Август 2011, 07:48:19 »
The work has progressed! Tomorrow I will restore pantograph because I came too soon! I had pictures from the side, but in the meantime I found a site dedicated numerous trams!
http://trenulete.info/tramvaiul-clasic-v-09-2/
prognosis
« Отговор #547 -: 10 Август 2011, 08:36:54 »
Class V 09 -3 tram
http://trenulete.info/tramvaiul-clasic-v-09-3/
We continued work we modified pantograph and directing me after photos. I stretched so far is correct in size and added damping and we changed his support. Pantograph is mobile and keep both up and down with a arculet and a lever mechanism.
The tractor wagon I made ​​mobile stairs. The real car, they are folded along walking wagon wall and stopping at stations, when you open doors, stairs to leave steps on them. My wagon doors are not opened, but steps are mobile.
Shopping and saving trick I made ​​with the bumper.
There was spray painting the car we used synthetic. The roof is painted with synthetic Revell. After final drying streaks correction will not come out perfect, although I used auto paint paper!
We made ​​the car light tractor. Lighthouse is central in terms of scrap kits houses. The case is so made ​​that unfold from the chassis without the intervention of soldering gun, rising to guide while the installation is mounted on the chassis.
София 70
  • Публикации: 622
  • София ,ТТ DR & DB ІV ер.
« Отговор #548 -: 10 Август 2011, 11:21:54 »
Prognosis ,this is so beautiful! Is this very difficult to work? I think that is. I very like trams models .Yours is so good hand make models.
My models is in cardboard and scale is 1:32.
prognosis
« Отговор #549 -: 11 Август 2011, 06:35:55 »
Class V 09-tram at the end
http://trenulete.info/tramvaiul-clasic-v-09-la-final/
Today I finished another chapter in my life amateur modeler. We have completed Class V tram 09. I have small corrections to even think about paint and windows to make the printer characters placed and standing in the tram, so that it appears more interesting than windows brumarii viewer that I fitted model.
This last tram came even charming. I do not know if pictures can convey what I feel, but seeing so gentle on the diorama, it is impossible not to fall in love with it instantly.
Of course my plans do not stop there. I want to work but still a car which does not say anything. It all depends on how I get another motor bogie. Modern trams are very beautiful, but small boghie imposibilitarea to purchase the transmission is a major obstacle to realization of models of current models. Even so, my great passion is for classical models, they are much more attractive and interesting, it presents an inconvenience in my way of preparing a diorama with trams.
Finally, we gladly offer some pictures and a little shooting.
http://www.youtube.com/watch?v=5jMjLkY1c1M
« Отговор #550 -: 11 Август 2011, 07:36:48 »
:good:
  • Публикации: 1465
« Отговор #551 -: 14 Август 2011, 11:26:09 »
Hey Prognosis,
I think you should be with us on our second  National conference and to participate with your models in the "competition". You are welcome with your beautiful trams or why not with sometging more- diorama or whatever...
Hope you have already seen the first banner at the beggining of the page next after the Head of the site.
You still have time to think on the idea to be together.
  • Публикации: 2045
« Отговор #552 -: 14 Август 2011, 11:50:19 »
Цитат на: emilchaushev link=topic=1087.msg64061#msg64061 date=1313310369
Hey Prognosis,
It's good idea!You are welcome!!! :good: :ok: :drinks:
« Последна редакция: 14 Август 2011, 11:53:57 от gregary »
prognosis
« Отговор #553 -: 14 Август 2011, 13:29:05 »
I read through google translate this page. It is very interesting and good for the Bulgarian and European enthusiasts. Unfortunately, you know, I do not have good financial standing. This movement is impossible for me, but thank you much for the invitation. It means a lot to me that you appreciate me and my work for railway enthusiasts!
prognosis
« Отговор #554 -: 18 Август 2011, 19:37:26 »
Automotorul VT 137/VS 135
http://trenulete.info/automotorul-vt-137vs-135/
Aceasta frumoasa macheta Piko, din vechea garda, a sosit de la Sibiu pentru inzestrarea cu sistem de iluminare pe baza de leduri. Am inlocuit vechiul ghidaj din metal, pentru becuri, cu unul facut pe baza de led-uri si matrita din forex. In rest las pozele si filmul sa vorbeasca de la sine.
http://www.youtube.com/watch?v=eWnH-OzdhBM
