Автор Тема: Uberwagon - lighting improvements  (Прочетена 13655 пъти)
prognosis
« -: 19 Януари 2009, 17:59:03 »
We're back on the wagon by Roco few modifications. First I entered the bridge rectifiers and I deleted rezistorul replacing the bulb with a 12-volt miniature. Light is much better now. Then I painted with metallic gray floor compartments to emphasize seats for a better light dissipated. Muscat bridge rectifiers have a toilet in the wagon. Finally I glued on the ceiling aluminum foil.
From Brasov I returned in December with a similar car but production Fleischmann. Something more detailed wagon shows how the advantages of openness and boghielor form. They culiseaza around the axes through a screw that has a beginning of a 1 mm hole on the inside. This hole we strapuns it to the inside and through it we crossed the line by wagon floor. Blades are used in copper 0.5 mm removed from a plate to contact the TV lamps. Have multiple blades. For this car and I made the final lamps leduri point. I imitation lamps out of the end wagon mounted there and I ledurile point in time entering the hole in the car. Subsequently these have related to the supply of on-board lighting through a resistor 850 ohm separate ledurile lighting.
Ledurile are perfect for lighting and I think I will change and wagon Roco. For example please see the shade difference between the two cars lights. LED lighting can be inseriate mini lamps 12 volts taken all of the zeXstar
  • Публикации: 2446
Re:Uberwagon - lighting improvements
« Отговор #1 -: 19 Януари 2009, 18:26:46 »
Някой би ли го попитал как го захранва това осветление?  :)
prognosis
« Отговор #2 -: 19 Януари 2009, 20:26:24 »
Schema nr. 2
  • Публикации: 2446
« Отговор #3 -: 19 Януари 2009, 21:32:39 »
Имам впредвид как токоснема от релсите, в смисъл сам ли си го направил или с оригинални купени за тази цел пластини?  :unsure:
prognosis
« Отговор #4 -: 19 Януари 2009, 23:29:04 »
Преводът е лошо ... Но ако разбера ...
E схемата си помислих, че ме и аз да се прилага плочи, направени от мен. Купих. Видях!
  • Публикации: 2446
« Отговор #5 -: 20 Януари 2009, 08:08:28 »
Ще го кажа по-просто:
-Как вагоните вземат ток от релсите?Можеш ли да ги снимаш отдолу? Дали с купени пластинки от хоби - магазин  или сам си ги направил и ако ти си ги направил - то от какво и как?  :)
  • Публикации: 2006
« Отговор #6 -: 20 Януари 2009, 10:12:57 »
Va spun mai multe, pur şi simplu:
Cum vagoane ia putere de la piesa? Poţi să le fotografia de mai jos? , Indiferent dacă acestea sunt cumpărate de hobby platouri - sau le păstrează în sine şi, dacă nu-i - ce şi cum?
prognosis
« Отговор #7 -: 20 Януари 2009, 10:25:38 »
Boghiul движат около оста чрез винт, който е начало на 1 mm отвор от вътре. Тази дупка ние strapuns нея и чрез нея ние пресича линията от вагона етаж. Лопатки се използват в мед 0,5 mm се отстраняват от контакт карта от лампа по телевизията. Имате много ножове.
Лопатките са установени на място, в рамките на съществуващите талигата и са уловени с капка лепило CA
Аз никога не са използвали еластични лопатките на търговията. Те съдържат желязо или стомана и ruginesc страхотно, но проблемът е, че rulaj Освен това, те водят до оси моста и да ги унищожат. Доказателство, че се придържате към в магнит ...
Използвах медни ножове показва какво всички, които са дълги пистите вагони. Те oxidizes и като оси оси ...
« Последна редакция: 20 Януари 2009, 10:27:25 от prognosis »
prognosis
« Отговор #8 -: 20 Януари 2009, 15:29:42 »
Confection - riglete sell lighting of LED plexiglass
valid for cars and buses H0 or greater
Made to order riglete on transparent plexiglass sheet, with white-hot leduri control and power absorbed by the bulb.
Advantages:
- The current system regulates leduri in the consumption of network requirements and the current ledurilor;
- Prisma of plexiglass is perfectly polished so that light is distributed evenly throughout wagon;
- Installation and worked perfectly in digital and in analog;
- Rigletele works regardless of the purpose of travel;
- With rigletele delivered two blades and contacts to put the car.
Rigletele can order depending on the length of their wagon and the price is calculated according to the number of such leduri mounted:
1 euro for each LED incorporated plus taxes expedition.
Rigletele interested can order by any measurements of length wagon. Leduri calculation of the number required to do by measuring the area illuminated, so that distribution is ledurilor lighting and balanced outcome to be uniform in all wagon. Following the same principles run like lighting and H0 scale vehicles (buses)
comenzi
  • Публикации: 2446
« Отговор #9 -: 20 Януари 2009, 19:12:56 »
Цитат на: prognosis link=topic=1283.msg17521#msg17521 date=1232439938
Това какво означава? Да не са от радиолампи извадени тези пластини?  :no:
« Отговор #10 -: 20 Януари 2009, 21:14:16 »
Вие двамата много ме кефите.Такъв мохабет правите ;D :clapping:.Ице, аз ако бях на твое място досега да съм запалил колата и до Румъния на рандеву :yes: :im_so_happy:
  • Публикации: 2446
« Отговор #11 -: 20 Януари 2009, 21:36:52 »
Да ида, ама ще умра от глад там! Не мога комат хляб да си поискам на румънски!И английския ми е много куц... :dance1:
« Отговор #12 -: 20 Януари 2009, 22:03:15 »
Water бе майна е вода :yes:,Bread -хляб.Казваш one bread и water ,попара праиш,густо става,на вагоните тока им пускате и всичко екстра :yahoo: :lol: :pleasantry:
  • Публикации: 2446
« Отговор #13 -: 20 Януари 2009, 22:14:08 »
 :lol: :lol: :lol:
prognosis
« Отговор #14 -: 23 Декември 2010, 14:31:01 »
NU prea inteleg comentariile voastre! Traducatorul google face mari erori iar textum este neinteligilbil! Imi pare rau dragi colegi!
Не разбирам вашите коментари! Google преводач прави големи грешки и е neinteligilbil textum! За съжаление скъпи колеги!
Do not quite understand your comments! Google translator makes big mistakes and is neinteligilbil textum! Sorry dear colleagues!
