Автор Тема: Продукти на ESU | ESU products  (Прочетена 22793 пъти)
Dispatcher
  • Administrator
  • Публикации: 79
« -: 13 Септември 2007, 11:21:16 »
ECoS-Just play
We are proud to present to you our ECoS Digital Central Unit. ECoS is not just another Digital Central Unit on the market: ECoS is the first stepping stone to a comprehensive Control-System, which, with new concepts, will address the subject of model railroad control systems, and revolutionize it. Never was it simpler to run a model railroad.
An important message for all the Pro's: In spite of the entire new innovations, we made ECoS compatible with all existing systems. You can continue to use your present equipment. Now. Promise. Discover the fascinating possibilities of the ECoS Central-Station on the following pages. But take heed: ECoS performance is so good, that even we had to reread a few passages, to believe it...
ECoS Features
Consequently with ECoS we want to continue in the same direction we started out more than seven years ago. The ECoS Central Unit is the first Digital Command Station with our name. You may rightly expect more from an ESU-Digital Command Station from the house of ESU. From the beginning we wanted to be open to, and compatible with, present systems and norms. Just as the first LokSound decoder was a Multi protocol decoder, ECoS is also enormously flexible: As a Multi protocol Central Unit, ECoS supports the formats DCC, Mдrklin®-Motorola® and Selectrix®, which means you can continue to use nearly all of your present loco decoders.
With ECoS you can run locos: Via two integrated Cabs with large, easy-grasp motor driven (!) throttle knobs and eight precise click-function keys you control your locos. In combination with the touch screen, you can control up to 20 functions per engine.
With ECoS you can switch turnouts and magnetic driven accessories: Via a large, graphic switchboard you have access to up to 1420 turnouts (DCC or Motorola® format).
With ECoS you can lay out and control routes: Simply put turnouts and magnetic accessories graphically in groups and switch them together. Routes will be activated either by s88 occupancy detectors or by key.
With ECoS you can operate shuttle trains: Put a s88 rail contact at both ends of the track, and ECoS will do the rest.
The ECoS built-in booster has so much power that in most cases you don't need additional ones.
Who Needs ECoS
ECoS is basically the central station for all. Beginners, who are looking for a simple-to-operate Cab, will be at home right away: The large, graphic touch screen display shows all information in plain text; in case of doubt use the integrated help function. Never was it easier to switch to digital control. And ECoS runs DC or AC driven trains. Even model railroaders, who already own a digital command station, should step up to ECoS: Next to the extreme simple inputs, and the possibilities for route and shuttle train programming, you will learn to appreciate the manifold programming features for decoders. You can connect your present equipment to the input of EcoSniffer, and continue to use it: You don't need to discard anything that you want to keep using!
Due to its enormous output-performance, the ECoS Central Station is recommended especially also for operators of Gauge 1 or LGB layouts: At last you can run multiple trains without an external booster. Total interplay with our LokSound XL decoders is matter-of-fact.
Source and additional information can be found at http://www.loksound.de/us/index.php?showId=205
« Последна редакция: 15 Септември 2007, 19:42:33 от Dispatcher »
Dispatcher
  • Administrator
  • Публикации: 79
Re: Продукти на ESU | ESU products
« Отговор #1 -: 15 Септември 2007, 19:38:55 »
LokSound Family
"Digital command control with original sound"
All LokSound decoders combine a high quality digital decoder and a digital sound module on one circuit board. You can operate your locomotives digitally and at the same time replay the original sound as well as special sound effects such as horn or whistle. The sound is adjusted to the particular running mode at any point in time: when the loco starts moving, you hear the appropriate sounds (diesel engine revving up, steam chuffs with increasing frequency) and when it stops, you hear the engine slow down and also braking sounds.
LokSound decoders set the trend in terms of technology and sound quality. Besides the features you would expect from a state-of-the-art decoder, they offer many more:
-Autodetection of digital or analog operation
-Suitable for any Digital Command Control (DCC) system, including: Digitrax®, NCE, MRC® DCC, Atlas® commander®, Bachmann® E-Z command®, Lenz® digital plus®, Zimo®, LGB® MTS®, ROCO®, Fleischmann® Twin-Center®
-Suitable for AC-, DC- and coreless motors
-Super silent running due to pulse frequency of 32 KHz
-Perfect load compensation for optimal running especially on uphill or downhill gradients; exceptional slow running characteristics
-Load control can be adapted to any motor by means of 3 CVs
-Dynamic Drive Control (DDC) - Back EMF active at low speeds for smooth slow running operation with reduced influence at high speeds
-Back EMF also active in conventional AC or DC mode - User has full control of motor and acceleration
-Acceleration and deceleration can be switched with function button
-Switcher mode (half speed) can be activated with function button
-Up to 4 auxiliary function outputs suitable for smoke units, interior lighting, automatic couplers, for raising and lowering pantographs, ditch lights or lighting the fire box
-Individually adjustable brightness of lighting
-Special lighting effects such as blinking, fire box, Mars light, Gyra light etc. can be set for each function individually
-New, revolutionary function mapping. All functions can be allocated to any of up to 20 function buttons. Multiple allocations are possible allowing for the combination of sound and functions e.g. the sound of shoveling coal and light flickering in the firebox
-Integrated Function Keys F13-F20 - latest NMRA DCC standards
-Short circuit protection for motor and function outputs
Realistic sounds - as in the real world - can easily be reproduced with the sound module, because the original sounds are memorized digitally on a chip. The sound module offers a new and fascinating model world full of sound.
-The 4-Channel feature allows you to add 3 sound effects simultaneously to the running sound, your engine will sound even more realistic.
-Really hear your engine work - exhaust chuffs synchronized to the wheel and to the load - lower motor revolutions for diesel engines once the set speed has been reached - separate running sound and ventilator sounds for electric locomotives.
-Load Dependent Sound - may be turned off
-The sound speed is synchronized with the speed steps or with an external sensor. This is suitable for use with mechanical sensors, reed switches or Hall sensors.
-Your model railway becomes more authentic than ever with the large 8 MBit memory allowing for complex sound effects, such as the typical noise of a stationary steam engine, the announcements by the dispatcher, the whistle of the train guard and many more. You can activate up to 15 different sounds with the function buttons.
-Adjustable sound volume - Control the volume for the prime mover, horn or whistle and bell individually; accomplished by the use a function key on the command station throttle or adjust the CVs.
-With the Helper Function the user can select whether the engine runs standalone, head-of-consist, mid-of-consist, or end-of-consist. Certain functions can be enabled/disabled, for instance the horn and bell is active on the first engine only, whereas the prime mover sound is on for all engines.
-Consist mode CVs - Influence the behavior of the function keys with the added CVs 21 and 22.
-Analog Sound - Even on conventional DC layouts you will hear all prime mover sounds synchronized to the operation condition.
Types:
LokSound V3.5
LokSound micro
LokSoundXL V3.5
LokSound mfx
Source and additional information can be found at http://www.loksound.de/us/index.php?showId=113
Dispatcher
  • Administrator
  • Публикации: 79
« Отговор #2 -: 15 Септември 2007, 19:42:12 »
LokPilot Family
"The standard of technology excellence"
The LokPilot decoders are the perfect choice for the advanced model railroader. Versatility and reliability are qualities you would expect from ESU. No matter if you operate it using NMRA/DCC or conventional DC, the decoder will automatically detect the operation mode. In DCC mode the decoder determines the number of speed steps and you may select any of 9999 addresses. The individually programmable speed curve allows precise adjustment to match a particular model. Our truly universal function mapping allows all function outputs to be assigned to any of 12 function buttons in any combination. LokPilot supports lighting effects like Mars Light, Ditch Lights, Gyra Light, Strobe Light and many more. The brightness of lighting is individually adjustable.
Of course, the LokPilot offers the unique Dynamic Drive Control (DDC) feature where the Back EMF is active at low speeds for smooth slow running operation with reduced influence at high speeds.
Fitted with overload protection for the motor output as well as the four function outputs, the decoder is extremely robust. It is suitable for DC, coreless and universal motors converted with Hamo magnets. The 40kHz high frequency motor control assures smooth and silent running.
We put great emphasis on maximum performance of our decoders. The motor output handles a maximum current of 1.1A while the function outputs are designed for 180mA each.
-Super silent running due to pulse frequency of 40 kHz
-New, revolutionary function mapping. All functions can be allocated to any of 12 function buttons. Multiple allocations are possible allowing for the combination of sound and functions e.g. the sound of shoveling coal and light flickering in the firebox
Source and additional information can be found at http://www.loksound.de/us/index.php?showId=131
Dispatcher
  • Administrator
  • Публикации: 79
« Отговор #3 -: 15 Септември 2007, 19:43:46 »
LokSound Programmer
The ultimate accessory for programming with ease
With the aid of the LokSound Programmer you can simply modify the sound of your locomotive or optimize the synchronization of the sound with the drivers. Never was it easier to adapt a digital decoder to your model! The only requirement is a PC with an audio card and Windows® operating system. You do not need any prior knowledge or experience in programming.
Here’s how easy we have made it for you: simply connect the LokSound Programmer to a serial port of your PC or use the included USB-adapter. Start the user-friendly LokSound Programmer software, place a decoder-equipped locomotive (from the range of ESU decoders) on the programming track and you are ready to read-out, modify or reprogram the decoder data. The software automatically detects which type of ESU decoder has been installed. The graphic interface offers various customizing possibilities in an intuitive way – specifically adapted to each decoder type. Your modified decoder will fit optimally to your locomotive.
Here are some of the features you can change with the click of a mouse:
-Address, number of speed steps, acceleration and deceleration
-Load control, speed curve and analog functions
-Assignment of function buttons with lighting effects and adjustment of brightness
-Adaptation or complete replacement of current sound project
-Creation of new sound projects
-All special settings
Source and additional information can be found at http://www.loksound.de/us/index.php?showId=47
Dispatcher
  • Administrator
  • Публикации: 79
« Отговор #4 -: 15 Септември 2007, 19:47:45 »
Accessories
Our speakers have been developed for LokSound decoders. The speaker, the sound chamber and the LokSound decoder are adjusted to each other to guarantee a perfect sound experience. Therefore it is a neccessity to install our unique speakers.
Speakers for LokSound decoder (N, TT, H0, 0)
NEW!;50339;Speaker (13mm), round, 100 Ohm, without sound chamber
NEW!;50440;Lautsprecher 0.62''x 0.98'' (16x25mm), square, 100 Ohm, without sound chamber
Available in various sizes, namely 0.51'', 0.63’’, 0.79’’, 0.91’’, 1.10’’, 1.57’’, 0.62''x 0.98 and 0.79’’ x 1.57’’ (13mm, 20mm, 23mm, 28mm, 40mm, 16x25mm and 20x16mm). Should there be insufficient space, the speaker may have to be installed in a permanently coupled wagon– directly behind the engine. The sound chamber is an absolute necessity, since it provides the required pressure to the membrane of the speaker.
Speakers for LokSoundXL decoder (0, I, G)
LokSoundXL decoders come without speakers and you have to purchase the one best suited to your model. Speakers for LokSoundXL are available in three dimensions, namely 1.57’’, 2.24’’ and 3.07’’ (40mm, 57mm or 78mm).
Adapter cable with 8pin connector for locomotives that are not supplied with a NMRA standard interface. (Cable colors according to DCC norm / 11.81'' (300mm) cable length)
Source and additional information can be found at http://www.loksound.de/us/index.php?showId=134
« Отговор #5 -: 07 Януари 2016, 09:47:36 »
Гледам, че вече и някакъв подвижен състав се продава под марката ЕСУ. Някой има ли представа това ребрендирано (ех че убава българска дума) нещо друго ли е или са си техни?
  • Публикации: 12283
« Отговор #6 -: 07 Януари 2016, 09:49:32 »
Дай снимка или линк за да схвана за какво говориш  :resent: :resent: :resent:
  • Публикации: 6710
« Отговор #7 -: 07 Януари 2016, 09:56:24 »
« Последна редакция: 07 Януари 2016, 10:05:35 от Adrian »
  • Публикации: 2006
« Отговор #8 -: 07 Януари 2016, 11:52:07 »
:) вадат Зазо и виж какво ... :) почваме ли побългаряването. Вади номерата и бройките от тефтера ;) и да почваме ...
  • Публикации: 6710
« Последна редакция: 07 Януари 2016, 12:04:15 от Adrian »
« Отговор #10 -: 07 Януари 2016, 19:15:45 »
Иво, недей.   :haha: :blink: :lol:
Ако знаеш тези колко вида са. Пък после у нас какви ли трансформации са търпели не ми се мисли.
