Автор Тема: Prognosis H0 model railroad - "The town from the dining room"  (Прочетена 483168 пъти)
prognosis
Re:Prognosis H0 model railroad - "The town from the dining room"
« Отговор #450 -: 18 Ноември 2010, 15:04:26 »
Sorry for the mistake. Because emotions and fatigue ... :yes:
prognosis
« Отговор #451 -: 22 Ноември 2010, 11:18:23 »
Maintenance - interior furnishings, the couple cut short and inscriptions
http://trenulete.info/intretinere-mobilier-interior-cuple-scurtate-si-inscriptionari/
This weekend I worked a few trinkets, which, however, seem insignificant though, kidnap quite long.
First I made interior furnishings that remained indebted to Automotorul Prognosis. I want to do and an electrical coupling to power the lighting in car tow tractor wagon, so the train stops from where the tractor stops on a line segment energized, the parking lights remain lit, this time for a special note to my analog system.
Then they came for the stickers, I've written on here and there, in important respects. Priority is bonding with the inscription of the electricity, lightning warning. And for my diorama, the city is invented by me, we ought to dedicate some PanArin depot wagon, which I also made a logo and an inscription for freight cars ...
For some coaches Piko, classic axle couplings were oversized so ancient distance between tapoane was over 10 mm. Compared with other joints, all Piko and all the old generation, fixing holes were different, so ...
And in addition, we completed the collection of dedicated gondola transport trolley, with another car ... made by Gondo method for trolleybuses
prognosis
« Отговор #452 -: 22 Ноември 2010, 15:19:54 »
Drill home made
http://trenulete.info/masina-de-gaurit-home-made/
How do I drill a large, 220 volt, but whose small spiral chuck can not catch, so necessary in models, I decided to use the engine PanArin stores, something old, 24-volt used in the old windshield wipers to trams, to build a drill smaller and easier to handle in models, which have not beat the strands of 1mm or thinner.
For this, I ordered a lathe chuck a reduction from an old mine, a hand drill and screw shaft of the motor. Also I did everything turned aluminum, a pressure cap on the motor shaft to adjust the pressure with a ball and a spring and there are still cool and engine lubrication
The handle is made of textolit engine and comes with strips of aluminum plate and screws. The handle I placed a starting Micro. The machine is fed through a feeder trains FZ1. Unfortunately not much jaw chuck ....
But it's important that you make yourself a mini drill Scale models.
prognosis
« Отговор #453 -: 23 Ноември 2010, 09:57:10 »
The American Mehano with directional lights
Film presentation http://trenulete.info/inca-o-americana-cu-fason/
Came from a particular depot in Ploiesti, the American locomotive, product range Mehano hobby, is the U.S. sent two directional lighting installation. As we have done and first, I made holes for the red lights right in dwellings position lights imitated in the case. For that, the first was scored with a sharp needle, just the center hole where it will locate the front position. To perfect score in the middle, with a file to slightly flattened hemispherical shape of the lamp housing imitated in the locomotive. Propriuziză drilling followed the steps, spirals ever higher up the scale LED punctiform type which was to be used. Drilling in speed is necessary to keep strictly to the exact shape of the hole center lamp housing emulated.
Point red LEDs are connected in parallel and in series with a 920 ohm rzistor plate mounted above the engine. For central lighthouse we used a white neon light, a resistor in series with 820 ohms. Light is positioned so that light can be applied to both headlights stacked central and part of it be passed on plates with numbers and specific light American locomotives.
For extra effect, I placed in the cabin and a 12 volt bulb that gives a pleasant light in the cab.
prognosis
topalov
« Отговор #455 -: 24 Ноември 2010, 22:38:58 »
Very good job! Congratulations!
prognosis
« Отговор #456 -: 26 Ноември 2010, 12:25:49 »
My Diorama in local media attention
http://trenulete.info/diorama-mea-in-atentia-presei-locale/
November 25, 2010 Yesterday, in truth the evening newspaper appeared an article about my diorama intention to Modeling founded a club in Slobozia. Maybe this time, authorities will be more cooperative and I will support to children and enthusiasts in Slobozia, a puncture of attraction and power in the arts rail modeling. I think it's appropriate for them to have a place where their passion could take shape, where the change imresii and experiences, where to make art in a controlled environment. It's a shame not to see the world through these works, it's a shame not to be in town a place where children practice and learn to build. I like a little effort from the County Council, the Mayor would give the city a good thing and prove that the administration engage in the act of promoting local talent and to encourage constructive hobbies.
« Отговор #457 -: 26 Ноември 2010, 12:31:34 »
760mm
« Отговор #458 -: 26 Ноември 2010, 12:41:17 »
 :clapping:
« Отговор #459 -: 26 Ноември 2010, 15:37:04 »
 :clapping: :clapping: :clapping:  :good:  :hi:
prognosis
« Отговор #460 -: 28 Ноември 2010, 17:30:42 »
Classic car - LED lighting
http://trenulete.info/vagon-clasic-iluminare-cu-leduri/
A nice classic car with lights, came from the Banat region, received a white LED-based lighting, hot lights and lanterns for the final. After the principle applies to other cars with lights, we used light plexiglass 5 mm thick, in which we positioned peduri white hot. The ends were polished with emery lens removes the effect of magnifying your replacement light. LEDs are positioned to the top of the beam and the light is reflected from the ceiling skylight that I bonded foil so as to be illuminated and skylight windows.
The five ceiling lights are connected in parallel and in series with a 12-volt mini bulb and lamps are in series with a resistor of 820 ohms. The cabin is situated toilet miniature bridge rectifiers. The collection is made osiillor axle with slats Rally model (sent by the client) ...
Multumesc Bulgaria Colegue
prognosis
« Отговор #461 -: 04 Декември 2010, 11:08:44 »
Ancient ships, another front of me modelist
It was a time I toyed with great pleasure, passion and patience, with water modeling. Passionate RuneScape player, since the game was released, I loved a lot and I tried to replicate the virtual environment used in the game ships. I had plans, I only studied some of the images in the play-on and after these milestones, plus imagination, I have reproduced these beauties. For long, the boats stayed in a restored shelves of a friend who bought all the ships at a time when my life changed, I got sick with asthma and I lost my job. Boats were for a time in life, as I am assured that the money necessary treatments. Later I regretted their alienation, especially because now I could not bear the dust resulting from grinding wood, but they remain a part of my passing on this earth!
For almost one hundred pictures of these ships, I apologize for forwarding and invite those interested to see them on my site or photobuchet
http://trenulete.info/corabiile-antice-o-alta-fata-a-modelistului-din-mine/
http://s1204.photobucket.com/albums/bb409/Arin_Panait/corabii/?start=all
prognosis
« Отговор #462 -: 05 Декември 2010, 17:44:02 »
Small car - LED illumination
http://trenulete.info/vagon-mic-iluminare-pe-led-uri/
After some time they arrived in Botosani a series of four small cars, from Piko, old model, who were destined for dismantling and use of chassis units for future construction Malaxa 900/77. After thorough investigation we concluded that the body is shorter and therefore gave up their disposal. After last week I changed their couplings, today we began equipping them with indoor lighting.
Strips are made from circuit board and contain four 1N4005 diodes as a diode bridge, a 1k resistor and the 3 SMD LED. Diodes and resistor are mounted on the top and so are hidden under the roof, simple scheme of image
... And on the plate, directly on the copper levels are only three "lights" yellow smd, given that cars are antique lamps and lighting is by whose light was yellow.
The axles are attached to metal hanger, the collection is simple, no slides, only two wires bonded closely over the shoulder metallic osiilo sharp peaks, r with minimum friction and without the need of blades. A very good and effective blood collection, one pole of the axle and a second from each other.
The plate is pierced for the passage of mounting guides on the wagon chassis. Removing and extracting placutei for intervention is no other problems.
A capacitor will be built in to cover the toilet cabin pressure drops during turnover.
Follow the rest of the coaches, the last going to be mounted lamps and lanterns upper end. But after we get this and other cars because the original metal axles were fitted with plastic axles.
prognosis
« Отговор #463 -: 07 Декември 2010, 17:26:06 »
Small car - LED illumination - 2
http://trenulete.info/vagon-mic-% E2% 80% 93-on-light-LED-2 /
I continued with light cars in this set. I worked circuit boards, all at once for ease of production. We made a little longer to lean on better housing and to secure a cabin built on the ends so you no longer see the window light. Basically I have fun with another 2.5 mm high, but still see the lights and as such I will proceed to other changes for the next car, and will process and apply to those already installed.
prognosis
« Отговор #464 -: 11 Декември 2010, 13:03:45 »
Karos bus B-732 - mounting kit (not recommended)
http://trenulete.info/autobuzul-karosa-b-732-montaj-kit-nerecomandabil/
Recently arrived in the country for assembly Karos B-type bus 732, developed by Czech company SDV models. The kit came to me because the owner found himself in the awkward situation of being unable to solve due to poor installation of sheet examples of explanations. That's very straight, recall that a year ago or so, and I've gone through those moments when I installed Tug TATRA car produced by the same company and sold almost everywhere in our country. Maybe in another manufacturer, model to be of better quality, but SDV Models, at least by what appeared on the Romanian market are ashamed of such nonsense modeling Sale inexperienced enthusiasts. Moulds very bad times spent with burrs huge gaps, chipped or misshapen parts, and brief explanations board the wrong places, you are nothing more than create a complete state of irritation and discomfort when you begin to build a product kit This Czech company. So I understand the frustration of fellow who gave up to till this model. Personally I would be disposed of in any case I would not try this experience. The layout is terrible, made no accuracy or precision parts, prone to suicide for those who do not have patience or experience, why not recommend anyone to try to SDV Models kits, unless you really want to learn new and long series of specific swearing ... .
IN WITNESS WHEREOF, I have willed to go out this great layout mess.
First I removed the windows did not qualify as fair in their dwellings and who were still stuck and you have forcibly and smeared with fingerprints of the holder.
As such, we removed the fingerprints and scraping excess adhesive to climb, sanding with very fine sandpaper and then finished with felt and pickling paste.
He attended the trimming and finishing ... cauciucurilo window frames and edges tuturot infamous cast.
I removed all hardware holes parked purposely to hamper the work modelist ...
We cut and finished all recoverable components on the frame casting.
We adjusted and polished wheel axles which fit with everything but the wheels and chassis of this machine is NOT!
I even rebuilt the axle holes were completely different diameter and position on the frame, than it would be for the wheels to come in the correct position.
Removal of all stored holes plate casting and bringing the vehicle interior furniture rates by sanding with sandpaper ...
Wheel and axle assembly Regaurirea ...
Revell Acrylic Painting with aluminum floor and the stairs ...
Mounting body was the biggest challenge. That's because neither nohow, no walls between them did not fit nor the chassis. Explanations on the board did not describe them ... is useless!
Finally, the result is a toy acceptable, but the installation process and outcome are not worth any amount of money and no work, because the resulting model is beneath criticism, unfair and difficult stage of exposure brought a diorama ... You fully understand the former owner! Again, I suggest mounting kits passionate and not lose money with such a mess during installation. Just think how are advised to come out this crap and just in the Czech Republic, a country where high value is placed on product quality. It's a shame that a vehicle is so beautiful and famous in Europe, have no part as a model.
