Автор Тема: Prognosis H0 model railroad - "The town from the dining room"  (Прочетена 472924 пъти)
prognosis
Re:Prognosis H0 model railroad - "The town from the dining room"
« Отговор #480 -: 23 Януари 2011, 18:06:50 »
Stipp Auhagen Briescht building from -2
http://trenulete.info/cladirea-briescht-de-la-auhagen-stipp-2/
Construction of the station Auhagen continued today with the achievement of all nu.2 depot building. According to sketch this building is an annex side of the main station. Continuing the tradition and already has some experience, we have made and this work just like the previous ones.
In this section we encountered a problem roof design, which did not comply with the reality of combining the central building with the roof. After several tests, I found the solution and roof shape so I adapted to combine the two perfectly.
Here you can see the original form of the roof and drew pencil lines and then I made my cuts right changes. It's basically a design fault filmmaker kit, which I easily solved it by changing the geometry of joints according to the pictures.
prognosis
« Отговор #481 -: 24 Януари 2011, 08:28:27 »
Stipp Auhagen Briescht building from -3
http://trenulete.info/cladirea-briescht-de-la-auhagen-stipp-3/
The assembly building Depot Station continued with the 3rd wing, a shed with ramp, turn attached to the central building on its side. It's no board. 3 of this group of drawings. Installation are not always clear explanations and in most cases, intervention modellers, with imagination and talent, make work more successful than she designed fot ...
Being somewhat small, it was easier to install, especially as experience is gradually added and operating speeds. In general, such models, it takes longer to bake idea, but the work itself. If they work directly and only paper, it would be much easier, but the work would not have strength, remains somewhat fragile.
And if this holds, I cut out the windows and door frames to see the relief and enter the light after it is mounted on a mini-diorama you prepare as an accessory to Diorama Blumenberg. It will be virtually attached to it one way, a little smaller, a small depot in the age 3-4, with the necessary repairs and gararii of steam. In this way, smaller, can I go I want you and me to rail modelism various exhibitions in the country.
So, the magazine also provides a landing, the left image, which should be installed only by bending the paper print. I made more solid platform from 2.2 mm thick pressboard, over which I pasted printed decoration, to create a stiffer platform than the paper, which anyway had design flaw ... and not fair to the final blend.
Under the building, we set with pieces of adhesive to keep close to the bodies, they would dry up prenadezul which we combined. Note the plus side of a piece of pressboard, which connects the three buildings.
That piece is meant to strengthen the construction underneath, and on the surface, it will decorate the driveway crossings between the two doors, one in the building and the warehouse, and vegetation. In addition we add it and speed relief to the access doors.
At the end of the ramp, the stick spit, I made a small pillar sustinere.Pe rear, no door to the warehouse, but also ramp, which puts me in dilemma. Should I do the frame and on the back? Hmmm! I see the final there.
prognosis
« Отговор #482 -: 25 Януари 2011, 09:25:43 »
Stipp Auhagen Briescht building the final -4
http://trenulete.info/cladirea-briescht-de-la-auhagen-stipp-3-final/
Today I finally got to this work. The last pieces were worked to shed the entry ramp deposit, timber shed, and a few trinkets to the decor.
The final result a 3-4 overall construction time, with several buildings, which will equip the whole module you want to achieve in completing diorama Blumenberg. The book, quite laborious, spread over several days, but the result is something much more realistic than plastic, commercial work some more models, which is always enjoyable as the result of excellent work and very low price. Basically I took the computer model made of bottles, I laser-printed and I've used with cardboard pressboard, some match sticks, paper and other trinkets that you no longer lists. The result satisfied me. For those interested in the plans can contact me by email ...
« Отговор #483 -: 25 Януари 2011, 16:06:59 »
 :good: :good:
lubo_gumata
  • Публикации: 265
  • HO,4-5 еп.СЛИВЕН
« Отговор #484 -: 25 Януари 2011, 23:55:24 »
Hello. :)
 Very good deal :good: :hi:
prognosis
« Отговор #485 -: 01 Февруари 2011, 10:05:51 »
Lima Postal wagon Kol 105 114
http://trenulete.info/vagonul-postal-lima-105-114-kol/
The last of 11 311 seal Wt Lima, Kol 105 114 postal wagon, was purchased with the last Wt described below. The car was tortured by the old owner was trying to install interior lighting, little by ear. To repair the damaged buddy, I had to completely unravel the wagon, an operation that proved quite complicated because it's quirky design. Transparent plastic for the windows is a piece for all end and side windows and is placed in all slots and decupaturile possible, which makes it hard to dismantle it, especially as it joins the floor had been glued to his anteposesorul prenadez the chassis. Disassembly is very easy if toothpicks are inserted between the windows on both sides of the truck, then into one end to push the door windows of cars and shoot everything outside .... After disassembly and cleaning, I painted the floor with aluminum bronze and I mounted inside various transport crates and parcels.
As shown, the roof was also damaged by direct bonding of diodes with a very strong adhesive, which I removed with great difficulty ...
Being in my last car washer, we decided to have the final light. We used a new LED, 2 mm beam of light, which I entered through the wall and the exterior lantern I made of black plastic body, 2.5 mm thick, the clip material from closing / sealing a pipeline IDE socket on the motherboard of a PC.
For lighting I used in place of the board, a piece of forex (comatex) 3 mm thick, which I planted rectifier bridge, three light emitting diodes, current limiting light LEDs in series with the ceiling, (which I polished the end to remove magnifying glass), which are mounted in parallel. On the same board I mounted a 1k resistor in series with the lamp light the final. The wiring is copper wire from the cable network through this process can declare me as the inventor of the braiding process circuit, the cables being passed over for their safety by crossing various holes up and down the wiring board ... a process much simpler and more practical for those who do not or have not mastered the possibilities for wrapping in acid circuits.
All assembly is mounted directly on the wagon, under the ceiling and light Fizeau two pieces of bond paper (to put prices on products). Links to boghie lity are made with thin and flexible wires, the collection plate described in Item 11 311 wagon Wt
For light to see and eyelash extension roof observatory, I have chosen to Fret the inside where the skylight was faction observer, and I glued directly on the glass windows related.
On the side I glued white paper lantern I drew red signal lamp bars final.
And so my cars lining Lima has acquired a deserved place on the diorama, especially as cars are very beautiful with various elements and parts, with many accessories to mount the bellows extended to track shock to the floor that step is the passage of a wagon to another. There are many accessories in the kit mounted under the car, stands stairs, steps diverse pipeline, battery compartment, air tanks etc..
Thanks Pete for purchasing cars!
And a tip for owners of cars asftel LIMA, unhappy with the way they run. Coaches tend to jump on the curved lines on the piece, in slopes. This is because:
   1. the boghielor not too high a degree of freedom in the vertical plane. It is easy to solve by widening the hole axis pivot.
   2. axles are too tight on the track. Scoatrea be solved by a wheel on its axis and cylindrical grinding cylinder so easy distance of the wheel axle to be reduced by about 0.5 mm.
prognosis
« Отговор #486 -: 02 Февруари 2011, 11:06:14 »
Filmare cu garnitura de vagoane clasice de la Lima
http://trenulete.info/filmare-cu-garnitura-de-vagoane-clasice-de-la-lima/
Frumoasa garnitura produsa de Lima, in rulaj pe diorama mea, dupa modificarile aduse vagoanelor in Atelierele PanArin de la Slobozia.
http://www.youtube.com/watch?v=egBVQCVZuas
prognosis
« Отговор #487 -: 03 Февруари 2011, 07:24:21 »
66 183 wagon Roco - final lamp
http://trenulete.info/vagonul-66183-roco-lampa-finala/
The first phase, the mounting tensions collection facility. Collector blades are hot-glued on a piece of comatex, mounted under the wagon, in front of the axle, the chassis, so as to allow natural movement suprtului axle / springs, specify the type of wagon. After drying, the slide support bracket was painted the color of the wagon.
Photobucket
The wires run through the floor of the chassis, it was attached with adhesive paper.
Part Two, lantern making. We chose a 2 mm diameter LED. For lantern I used a piece of black plastic, and cut drills properly
they've combined the hole in the panel wagon. Nothing is Lipt, so anytime you can change only by extracting the LED lamp.
The last part, the installation of recovery and stabilization. I cut the weight of the wagon duramid inside to make way for bridge rectifiers and capacitor stability. The lamp is in series with a 1k resistor, followed by the output capacitor directly mounted miniature bridge rectifiers.
All frumnos enter into the case, is visible under the painted chassis and ... ... give the line!
prognosis
« Отговор #488 -: 05 Февруари 2011, 11:04:30 »
Vagoane cu coviltir – lampa finala
Tilt of the wagon with that of Piko Roco, received final lamps in a little different, and because it has the particularity of each wagon.
Piko wagon,
a counterweight is fixed with double adhesive metal in the middle of the chassis.
The lantern is a punctate red diode, which has the advantage of the approach of a lantern shape. Forex 1.2 mm thick, we gave a fixed hole diameter lens diode. I vospit black holes, the exterior of the plate and after drying I introduced and fixed with pressure drop, the light in that hole. After drying I cut the shape LED plate that is very close to the image of a lantern ... After filing the form I painted with black lantern sides won. I practiced in the wall of the wagon two 0.5 mm holes in exactly the right foot LED, which I entered and secured only by turning the legs inside the wagon up and down.
Collection wires go to a bridge rectifier, whose output is coupled to a capacitor to cancel healthy breaks. LED lamp is connected through a resistor 920 to capacitor 220 HMI micro/35 volts. Taking advantage of the great space was available in the car, so I installed a capacitor which, even after lifting itself off the wagon, keep the lights back up car in reverse and put it back on itself .... The condenser is attached to the wall of the wagon again with double-adhesive paper.
For plate fixation, we made a hole of 0.5 mm between the clips just bogie axis, we pierced hole and wagon platform. On the slide I soldered a thin, flexible wire coil removed from decommissioned. Lamela we set it above the hole through which thread a strip of 4 / 7 mm 0.5 mm thick cardboard forexde, slightly tipsy in transition right blade, to hold it firmly in position. I glued a strip directly over the blade fixing piece axle bogie. The whole piece can be extracted without further operations later than usual, with the axle bogie. I painted with brown chunks of forex which slides under the bogie and tin ... done. A car equipped with lamp finals.
Roco wagon
Bogie is something more complex and different Piko, axles having something inside, did not allow the mounting plate easily, which is why we chose the collection with pieces of elastic string guitar. I practiced holes of 0.1 diameter, Pein we passed a piece of string guitar.
In the middle, visible gap, stranded wire I wrapped up tightly around plate collectors, which I then passed through another hole, 0.5 diameter axle bogie practiced and so I brought the wagon chassis .
Duramid I cut weight to make room for a capacitor to maintain during the breaks, the output of a bridge rectifier connected miniature. I chose for the new type of lantern light of 2mm, which is quite long pipes to spread through the wall of the wagon and cut the size of a lantern plasitul attached to a car. The lamp is in series with a 920 ohm resistor mounted in the wall of the wagon ...
http://trenulete.info/vagoane-cu-coviltir-lampa-finala/
lubo_gumata
  • Публикации: 265
  • HO,4-5 еп.СЛИВЕН
« Отговор #489 -: 05 Февруари 2011, 11:30:46 »
Excellent,perfect1 :good:
  • Публикации: 6775
« Отговор #490 -: 05 Февруари 2011, 11:32:13 »
 :drinks:
« Отговор #491 -: 05 Февруари 2011, 21:55:36 »
beautifully :good:
hristo_t
  • H0 - IV DR/DB Бургас
« Отговор #492 -: 05 Февруари 2011, 22:33:06 »
 :good:
prognosis
« Отговор #493 -: 06 Февруари 2011, 09:42:13 »
Va multumesc tuturor pentru suport!
Hello modelers
Can anyone help me with this program?
http://www.theliquidateher.com/model-builder.html
http://www.modeltrainsoftware.com/
I do not have the resources to buy the software.
I promise to post on the forum all the planes of the buildings that I will build.
I thank you very much!
760mm
« Отговор #494 -: 08 Февруари 2011, 02:22:24 »
He's right. This can't be found for free, I tried hard to do so. And it looks like a great piece of software.
