Автор Тема: Prognosis H0 model railroad - "The town from the dining room"  (Прочетена 317335 пъти)
prognosis
Re:Prognosis H0 model railroad - "The town from the dining room"
« Отговор #510 -: 11 Март 2011, 10:21:06 »
EA 060 from Railway Memories
http://trenulete.info/060-ea-de-la-amintiri-feroviare/
March came one spring day, arrived in Botosani two wonderful Romanian electricity for interventions and improvements. The first of them, an EA Dolphin, had a disturbing noise curves and move at the same voltage, slightly more slowly than standard painted colors. I noticed when demonatrii, differences in the fastening system, the dolphin with only four points of attachment of the body chassis, while the classic, has 8 points of attachment, which reinforces more than two elements. To remove them easily, you can use a few toothpicks placed near the points of attachment, after which the locomotive back in normal position and is very easy to extract its own weight of the chassis ...
After disassembling and analyzing the Dolphin, I found two shortcomings that produce customer dissatisfaction. The first finding is that if one engine Wheel, placed too close to the engine, just touch the chassis wall, which led to friction, causing some noise and infranand rotation. A second finding, was that the two cardan transmission from dolphin, had casting defects, which are slightly off, which could create annoying vibrations and noise produced by the tremolo ... Also, the ends of the dial, crosses how are called, have a greater stake in the coupling nut, which leads to noise and annoying. Their remedy was made by straightening cardanelor hot and filling with silicone grease coupling nuts. So annoying noise, and speed deficiency decreased significantly by these interventions. As for straightening cardanelor, maybe not all models have this problem, the job holder you and good luck, but opposite ends of the universal joints, grease put in nuts, will probably reduce vibration for a while, but after melting and discharged, noise likely to be established again. There I found the same problems and the classical. This is perfect for cardan, front ends and nuts are combined game so great as to define and Wheel are slightly better placed on the engine axis, which induces the idea that it worked much more responsible than the latest pair, dolphin, or it was simply a bad luck of this Buyer!
For classic locomotive, the requirement was that the owner removes a shortcoming on the lighting. The fact found is that the engine is made by taking into prime interest to holders of digital satisfaction. Lighting scheme comprises four LEDs. Two yellow to white spots and two lights above the cab warm. In both cases, the lights are in series, doaua two, and then with one insriate SMD resistor value of 271 ohms each. Although the scheme has two ways of operation by changing a jamper lights, I believe that it was not designed to function properly in both digital and analog, knowing that inserirea LED current increases the initiation of production of light reflected in the drawback that, in analog and positions lights are lit only at very high speed running, ie the voltages or currents of power over jumatet variable. In the type Mehano I contatat a better, by firing at 30% of tension, while the drives Piko, just over 50% lights are barely, barely. This is quite annoying for the user of analog, quite widespread, that the price needs digitalis, not all collectors can buy the necessary devices. Therefore, after careful analysis of the pattern of operation, we chose an elegant solution that does not involve major changes to the motherboard and that will lead to satisfactory results in the normal operation of lights and analog parameters, given that proper lighting a model, the effect on the viewer grows exponentially.
How we did!
Well, first I changed the jumper position for the headlights only position at both ends, so that the second yellow LED SMD (God knows why they chose this color !!!), position of lights, end up in series with two 271 ohm resistors, a total of 542 ohm ballast.
We then stopped scratching, line plus (+) central headlight, thus eliminating their series-position lights.
I brought a strap which also have central headlamp powered directly, bypassing the headlights inseriarea position.
Since leaving the diode polarity directing, I took a voltage the resistor 580 through IMO, which I applied to the minus two of the SMD and central headlamp so I fed identical in each ballast resistance different but similar in value, each group of lighting, both top and bottom.
Thus, the two groups came to light with the same value of red light, which worked perfectly before surgery, and at this moment, the light became operational in the analog voltage values ​​close to starting time. Aprid mean is applied relatively quickly to lower tensions toy, releasing a pretty obvious drawback for owners of analog. I think that could solve the problem of manufacturing by implementing a simple scheme based on the jumpers, which will satisfy both categories of clients, but probably the economic nature of the producer, that spare parts would lead to increased price toy. But I think it would be justified, considering the fact that there are many similar users who love this beautiful locomotive, with whom we Romans, I grew up and we traveled on railroads in Romania during all these years and that trains an unspeakable passionate love.
prognosis
« Отговор #511 -: 11 Март 2011, 17:46:21 »
060 EA in Orasul din sufragerie
Cele doua bijuterii de locomotive, produse de Amintiri Feroviare, sosite de la Botosani pentru remedieri si modificari, in rulaj pe diorama “Orasul din sufragerie”. Se mai pot observa si cele doua vagoane romanesti, 51 53 19 si 51 53 20, vagoane in care am montat iluminat pe leduri tip smd. Lucrarile pot fi accesate AICI si AICI.
Locomotivele sunt excelent realizate, visul oricarui modelist roman si nu numai. Felicitari producatorului pentru reusita, desi pretul nu este pentru toata lumea!
http://trenulete.info/060-ea-in-orasul-din-sufragerie/
http://www.youtube.com/watch?v=k9uGmLs5JTk
lubo_gumata
  • Публикации: 265
  • HO,4-5 еп.СЛИВЕН
« Отговор #512 -: 11 Март 2011, 20:15:13 »
Bravo, amice! Eşti doar perfect! :hi:
prognosis
« Отговор #513 -: 11 Март 2011, 20:28:25 »
Multumesc! :good:
prognosis
« Отговор #514 -: 13 Март 2011, 12:34:18 »
Postal Umbauwagen - improvements (Fleischmann)
http://trenulete.info/umbauwagen-postal-% E2% 80% 93-Fleischmann-improvements /
The last piece in the collection of wagons Umbauwagen, namely wagon semi, post / grade. II, was also subjected to operations according to colleagues lighting garnish. Quite the colorful garnish, being composed of the same models of cars made by different manufacturers, whose improvements I wrote about in the pages of my blog some time ago. The train is composed of:
-Umbauwagen - improvements (Fleischmann)
-Umbauwagen - improvements (Trix)
- Umbauwagen - improvements (Roco)
Note that in all, Fleischmann wagons, are by far the most successful and the details, as well as building shape, although the biggest problem was the Fleischmann model, the difficulty caused by current passing through the middle wire to bring the metal screw bogie mounting. Be the center screw with spiral drills of 0.8 mm, very difficult thing without a well-centered drill, In addition, metal screw naughty opposes small coils, which are destroyed very quickly in the drilling operation against metal.
With the success of this operation, the rest is a breeze. I used to like his colleagues, the same types of LED white hot 3 mm diameter, polished the head for De-Screening fasciculuilui lens, LED mounted in transparent acrylic prisms. Although meanwhile appeared on the market and lower consumer LED, SMD type, I now use LED lighting for the same is not different from other coaches. However, for me, age 3 mm LEDs encased in Plexiglas, the last place was taken by smd's more practical.
Also, we took advantage of removing the model for the gray painted floor and make REVELL forex 1 mm thick floor plates that'll cover the area over the mounting screws. In these way, the light is reflected differently in the floor seats highlighting beautifully executed.
I placed the toilet in the cabin miniature bridge rectifiers, and I used to collect current from a copper plate of the switching engine destroyed preabuna Piko's functionality ...
prognosis
« Отговор #515 -: 25 Март 2011, 10:09:04 »
Romanian bunk wagon - lighting
http://trenulete.info/vagonul-etajat-romanesc-iluminare/
For the second time in history PanArin depots, wagon arrived for improvements made by Piko Romanian bunk. Slightly different than his brother presented a year ago in the link below, http://trenulete.info/vagonul-etajat-romanesc-iluminare-pe-led-uri/, this car received light based on LED smd white neon lamps and end at one end.
Collection of blood slides, Rally type, mounted in a classical style already collect axle voltages, each polarity for each bogie transoms and brings them into boards at each end. The recovery is riglete with four diodes in each of the two riglete, mounted by two in each end, so that finally result in a 1n4001 diode bridge rectifier.
For each light stabilizes rigleta many micro/35 1000 volt capacitor. Rigleta Each has its own recovery, filtering and balancing currents using a resistance of 810 ohms each for ceiling and a lamp k 1.2 final. Basically, this wagon, the lighting structures includes two cars, the difficulty consists in the correct location of the crossing with transoms and power cables, which must be concealed to the viewer.
This time I used all final Lamp SMD LED, mounted in rigletei upper end, the orientation prism light guide, so that once positioned rigleta, LED sends light through it and thus the lamp end. In order not to spread too much light red wagon in the end, the LED's and combining the prism is covered with a mask rigleta forex directly bonded under light.
The scheme worked this assembly then http://trenulete.info/schema-nr-8-pentru-iluminat-vagoane/
prognosis
« Отговор #516 -: 03 Април 2011, 08:48:40 »
Spring Cleaning
http://trenulete.info/curatenia-de-primavara/
Winter has passed and over Blumenberg! As well, the bad, the snows are gone and the city of the living room by decree drew everyone from general cleaning. Thus, with a cleaner car, or leaves collected from vegetation and removed dust from the roads and in parks. Hardworking people and have complied with every car washing and polishing. PanArin Railway Company and the self polishing with special cars made ​​in our own workshop and depot artisans began revisions in the spring to all rolling stock. After the activity, it remains a clean city, bright. On this occasion, the campaign "Romania take root", employees of greenery with a few volunteers have planted a total of 15 workshop PanArin shrubs grown in gardens, by the method branches Busch!
http://www.youtube.com/watch?v=jrtzrSW_fdU
prognosis
« Отговор #517 -: 04 Април 2011, 12:33:22 »
The trees in my garden
Film about various trees are home, using dry branches and sponge shock chopped or granulated textures of specialized trade. If no such textures can be used successfully and various dried spices, but in this case is absolutely necessary to use at the end of a spray hairspray because vegetation will not discolor over time.
http://trenulete.info/copaceii-din-gradina-mea-2/
thanks for that wonderfull camera
prognosis
« Отговор #518 -: 06 Април 2011, 18:35:56 »
Sfaturi pentru revizia unei locomotive H0
Film cu modalitatea de efectuare a unei revizii si curatenii de intretinere la o locomotiva Roco Br 218 cu decodor digital incorporat!
http://trenulete.info/sfaturi-pentru-revizia-unei-locomotive-h0/
topalov
« Отговор #519 -: 06 Април 2011, 20:55:30 »
Цитат на: prognosis link=topic=1087.msg57142#msg57142 date=1301909602
Very good trees! Congratulations! They look so real!
prognosis
« Отговор #520 -: 20 Април 2011, 08:51:43 »
Happy Holidays!
Feast of Souls Resurrection brings renewed hope and love for everything that is beautiful and true in life.
Along with my respect and best feelings you want to spend Holy Easter holiday with peace and joy in my heart.
I wish you a Happy Easter!
prognosis
« Отговор #521 -: 20 Април 2011, 14:17:09 »
Reconditioning a Warburg - 3
SERVO TEST FILM DIRECTION
http://trenulete.info/reconditionarea-unui-warburg-% E2% 80% 93-3 /
We continued work on refurbishment of this beautiful toy ... The main concentration was on solving the system of direction, especially considering that I rehabilitation by using a servo-steering mechanism operated electronically. Mounting the servo control scheme is presented side by side, fitting that we have made directly to the board reconditioned remote. Basically I made another control panel, so I planted the servo electronics, as well as buttons to go forward / back, at the horn, and in addition we installed a safety switch, a sort of mini Blackout, which provide current the servo control panel so not to be fed if not run the toy. All original remote in the box, I gave way and I mounted potentiometer for direction, we set the original steering wheel, after changing it, of course!
I am so happy because in my searches through boxes of monkeys, I found both the original horn, partially destroyed, and the original warning beacon. Horn has been reconditioned and works like 30 years ago ... will receive lights flashing warning beacon and strobe lights also will come with modern, I'll talk about later ...
Taking advantage of the fact that the overall direction will be subject to change, I imagined an additional signal steering system based on LED flashing. The device will work thanks to a base plate circuit boards and contacts, coupled LEDs will signal the slightest deviation from the straight line direction. The mechanism provides a disk, so corroded that they form a contact on each side of the rotation direction. Also, I intend and reworking the lighting, so the car will position lamps, stop on the brakes and steering back and I also installed a lamp and went back. I will not forget any warning beacon lights and all LED-based.
And because the first samples, original antique engine, proved a current blotting, we decided to replace it with a modern, 4.5 volts, with brush on coal, the Japanese brought a sophisticated toy destroyed a neighbor's child ....
prognosis
« Отговор #522 -: 26 Април 2011, 17:03:39 »
Reconditioning a Warburg - 4
http://trenulete.info/reconditionarea-unui-warburg-% E2% 80% 93-4 /
Next stage of the reconditioning of this machine with remote wired Warburg, was to restore the cabin interior, destroyed over time. Missing interior parts of furniture we have restored the ABS and Forex respectively 0.5 mm and 1 mm thick, glued and then painted with acrylic drops.
He followed the body painting. After studies on the net, I chose to paint the cars were piturate militia of the years 1970-1980. It is a dirty white matte and a glossy blue. I used automotive spray acrylic pane that I gave at an interval of 3-5 minutes. Acrylic paint has the advantage that it dries very quickly and goes quickly cleaned with alcohol if something is wrong. In addition, do not attack the plastic toy.
Meanwhile, I rebuilt and letters on license plates, also with Revell acrylic paint. I painted easily using a sharp toothpick.
The next day, after proper drying of the first layer of white that I gave the whole body, both inside and outside, I used paper tape for painting, which defined the two sides of the body color. After that, I applied blue paint, in 5 layers within 10 minutes, it asks for something more glossy paint drying time, although all acrylic specimen. I finally corrected with the same paint in places where not properly closed, using soft brush.
Dupa 3 zile, am montat caroseria pentru proba si iata ce a iesit…
fpk1999
  • Публикации: 507
  • Перфектният мащаб е 1:1 !!!
« Отговор #523 -: 01 Май 2011, 17:00:14 »
 :blink: :blink: :blink: :clapping: :clapping: :clapping: :hi:
hristo_t
  • H0 - IV DR/DB Бургас
« Отговор #524 -: 01 Май 2011, 17:05:32 »
 :good: :hi:
Well done! Wartburg is a nice car - full whit memories.
« Последна редакция: 01 Май 2011, 19:16:26 от hristo_t »
