Автор Тема: Prognosis H0 model railroad - "The town from the dining room"  (Прочетена 317179 пъти)
prognosis
Re:Prognosis H0 model railroad - "The town from the dining room"
« Отговор #495 -: 08 Февруари 2011, 10:31:09 »
UPS! I try me to but I can't find for free!
« Последна редакция: 08 Февруари 2011, 10:53:27 от prognosis »
prognosis
« Отговор #496 -: 08 Февруари 2011, 10:40:11 »
Public Toilets - home made of cardboard
http://trenulete.info/toaleta-publica-home-made-din-carton/
A piece of resistance, always present in the urban railway, the public toilet. Toilet, as this building is named in Romania. How we planned a long time making this work, as my latest achievements in the field of railway scale models were made at home by focusing on building paper models of Auhagen, I thought it was time to equip future workshops PanArin depot with such work. The project we have made the PC using Corel Draw and different textures on the net free. The pictures were great inspiration that you've done this summer the station's toilet Slobozia Veche, a book that I adapted it to the position it will have on my minidiorama depot. I mean we changed the input side.
Too many would not have to say about this building, being built by the methods described above all the buildings made of paper. To this, in particular, can observe the surrounding walls with oversized foundation. Because of the work done directly on the computer, I have a few small errors in the design side of the wall stuff that I will address today the painting project.
Who is interested in plans, contact me by email prognoza @ gmail. com cost nothing! It's free!
Finally, although it is a public toilet door, I hope with all my heart that my work is not ... shit!  :yahoo:
« Последна редакция: 08 Февруари 2011, 10:54:09 от prognosis »
760mm
« Отговор #497 -: 08 Февруари 2011, 14:16:39 »
"A piece of resistance, always present in the urban railway, the public toilet."
Cool toilets!
prognosis
« Отговор #498 -: 09 Февруари 2011, 14:03:56 »
Blacksmith Age 3 - home made
http://trenulete.info/fierarie-epoca-3-home-made/
Series cardboard buildings, buildings that will decorate my next section of the diorama, the depot three times, continued to forge achievement and associated warehouses. The work was made of cardboard and laser printed on A4 paper model building, model made in 2005 by American colleague, Godwin T. Petermann. In principle, the work was performed by the same methods described in papers presented before the board, except as window model, which border and inner comic. If only the paper work the plan, their location was not problematic, but only the paper work shows no resistance to manipulation or accidental harm. I have double walls with cardboard pressboard, 1 mm thick, which led to the placement of windows such complication. Basically, I cut cardboard, and then I installed windows over them, I stuck to walls. The benefit shows as a more detailed reperezentari.
Doors, wood type, and are open to the outside surface of the building, from previous models. steps we've not made of paper, too complicated when I comatex handy, of which we have made so much easier. In addition, extra support added to the bottom, the base is designed to inside walls, which I pasted below it, adding concrete driveway surface around the building. The forging furnace chimney hardware, I replaced mine with a piece of paper in pencil, which perfectly mimics the final piping. In addition, the bridge above the door, I placed a lamp shade made of white light / warm, polished lens. Abajurl is a metal washer, glued to drop the light and then painted black. Inside the wall we put 1k resistor in series with the lamp in question. Base building is trimmed to be introduced to the inner light and have a smoke generator in a Chinese toy on the batteries, I installed the generator in the building and I'll connect to the chimney of the forge.
Finally I added a few scattered bushes beside the chimney and corners of the building, befitting an annex to draw neaose! I will continue and draws a small achievement for a locomotive, and several other appendices perecum of a small depot. If you get the plans for a circular draws three lines, I try to do and such a building project.
prognosis
« Отговор #499 -: 11 Февруари 2011, 15:48:22 »
Draw small home made http://trenulete.info/remiza-mica-home-made/
An interesting draw, from the base at Fleischmann, has been the subject of my work lately. On the original board, we found inconsistencies between rates written in the drawing and the actual size pieces. Also, the design lacked some components, while others were badly cut. Although I wanted very much a unique draw for my locomotive, I could not use the board and as such we decided Fleischmann recreating the entire drawing. Basically I redesigned by reshaping hall by drawing walls and interior parts so you can use transparent windows and nice to see inside. Finally, the redesign draw on three A4 sheets, up from an initial, I rushed to print after print and I attacked the little hall diligently. Naturally I used the method that I used in my work presentation based on the drawing board and pressboard, the method is not much point to describe in detail.
Es-For its doors open as if it had hinges, I used paper that I gummed it in advance by anointing them with prenadez both sides, so that after drying, this vision of flexible and probabilities without breaking layer prenadez elastic and ensuring durability and mobility. Although the original design to provide windows and doors, created as a model rather childish, I finally decided that the door was not fitted with windows, patterned after the Auhagen did last year.
-At first we decided to achieve the outside, so that the whole building to blend perfectly on the outside, both the windows and cut corners. After closing the main hall, time for the magazine, the building behind the hall, all crafted from strips of cardboard pressboard, which I stuck over the end walls printed on A4 paper.
- He followed the building of glass and window frame transparency, the draw Auhagen patented method. I used black paper, packages from some old fart black and white photographs, maps packed they were to be protected from penetration of light, the paper is that the thing that does not allow light through, very suited to my frame windows ...
- So I cut strips of 1.5 mm and 2.2 mm thick, to make them bay window frames, big enough area. Support base, glass in my case being a simple self-adhesive transparent window lying beautiful model, for then he has woven the correct model, just after the original.
- Finally, windows were plastered on walls and over them I stuck with zidatia interior design, after I cut the original windows of course ...
- He attended the manufacturing floor interior, raised pavement so that they can more easily reach the locomotive depot artisans of PanArin ... Also I made the motherboard, that the sidewalk surrounding the building of the forex of 2.5 mm , then painted in gray. Platforms raised interior will be decorated with yellow stripes flank protection and they will line the interior, where I intend to mount a channel and Enterprise. Otherwise will follow the installation of lighting and installation before he made the roof, but they are subjects Days next activity.
prognosis
« Отговор #500 -: 13 Февруари 2011, 09:32:49 »
Next I proceeded to achieve lighting of the hall.
 I used yellow LED, 3 mm, for several reasons.
   1. Draw time is 3, so neon lighting is excluded
   2. These LED light is close to that of incandescent bulbs in those years
   3. ... I do not have LED white hot!
Thus, in the hall were mounted three LEDs, and one above the hall door, the lamp shade comes with washer and cap made of metal, stuck with superglue and painted black. All LEDs were polished to remove the effect of head magnifying glass and their similarity with a lamp shade.
Because LDH removable roof advised me to do, I gave up and I thought of sticking a blood collection system, which we have made use plugs from sockets for integrated circuits. I cut the two groups of two jacks, which I pasted on the wall behind a shed, which I connected to wires that come under the power draw to the board diorama, and one on the roof the roof, the LED constable sites through a 820 ohm resistor serially connected with the ceiling lights. All installation will power, as all buildings deltfel my 12-volt outlet stabilized 420 watt computer power, fueling my diorama.
I have LEDs mounted on the ceiling with duct tape, after which I pasted cardboard guides on all sides by walls blend with the shed roof, then I "Tecu and whitewashed ceiling using white photocopy paper. Finally, the roof is very easily extracted from the building and allow such intervention inside the shed, all this because someone wrote to me like building a house with a Barbie or Thomas drew! Anyway, now I am offered the opportunity to mount various accessories inside a familiar draws. Tool chests, work benches, trash, artisans and other small things that I made the journey. How PanArin Depot is equipped with a crane and a wagon catenary maintenance probably will develop the idea for each of them a box realixand related games ...
Most likely is the work of the doors for other interventions, to mount windows ...
lubo_gumata
  • Публикации: 265
  • HO,4-5 еп.СЛИВЕН
« Отговор #501 -: 13 Февруари 2011, 18:42:32 »
 :good: :hi:
prognosis
« Отговор #502 -: 14 Февруари 2011, 08:47:48 »
As already formed a small refrigerator gasket 6, I decided it was time to equip the train with a final lamp, cargo traffic is carried on more night Blumenberg. We chose a car from Liliput for coupling installation, simpler than the similar Roco, allowing trouble-free installation piece collection wagon axle.
http://trenulete.info/vagon-frigorific-liliput-lampa-finala/
The truck is composed of chassis and body with a roof, which is mounted by two bolts with hot melted end. I cut out the bubbly to break the climb and I disconnected the two components. For their refixarea I Drill spindle attachment, first with 1 mm to 2 mm and then to use minisuruburi. They are obtained with optical drives like crazy from the dismantling of deterioration, and removed from the powerful magnets.
The lantern is made of 3 mm thick and forex is provided by an LED light 2mm diameter, mounted through the wall pressure in the lantern, so they easily can be removed for any subsequent interventions ...
Part p energy is provided by bridge rectifier, 2200 micro/16volti an electrolytic capacitor, a resistance of 920 ohms. The entire assembly is mounted on the chassis floor with double-adhesive tape.
Current collection is polarized differently on each axle. To pass to the top of the chassis, we made 1.5 mm diameter holes through the plate weight.
As shown in the picture, the lamp continues to burn even after lifting itself ....
  • Публикации: 6738
« Отговор #503 -: 14 Февруари 2011, 09:25:22 »
 :good: perfect !
prognosis
« Отговор #504 -: 17 Февруари 2011, 11:39:00 »
Monastery Home Made
Zuge Dorfkirche the building (www.bahnsteig.de)
http://trenulete.info/manastire-home-made/
The paper made of cardboard, by methods described in the previous buildings, is a Catholic monastery type.
     -The model is printed on laser printer paper, cardboard applied on 1 mm thick pressboard.
    -cut and imitation glass windows made of medical adhesive that mimics the grain semi-transparent opaque glass, windows frames and edges black photo paper.
Otherwise let the images speak for themselves, any comment is superfluous ...
Who is interested in models made by me in paper and cardboard, can contact me by email.
n_sirakov
« Отговор #506 -: 06 Март 2011, 21:27:18 »
 :clapping: :clapping: :hi:
prognosis
« Отговор #507 -: 06 Март 2011, 21:30:38 »
prognosis
« Отговор #508 -: 07 Март 2011, 19:57:02 »
Cls passenger wagon. Series I 51 53 19 - Lighting
http://trenulete.info/vagonul-de-calatori-cls-i-seria-51-53-19-iluminare/
Lighting arrived in Botosani, two Romanian coaches at the depot today entered Tilligh PanArin for interventions. First, grade wagon. I received my home riglete made with white SMD LEDs, one for each compartment, or 9 pieces. LEDs are mounted in parallel to operate both analog and digital in, knowing that the series, the light is only slightly higher voltage, which is quite annoying in analog.
LEDs are serially connected with a 820 ohm resistor and an electrolytic capacitor using micro/25volti 1000, in parallel, remove palpaielile caused by interrupted supply or dirty self. Recovery was made with four diodes 1n4001 and blood collection were placed on slides using specialized sites. The thread passes through the middle bogie axle and axle plate acts both cars.
prognosis
« Отговор #509 -: 10 Март 2011, 12:34:26 »
Cls passenger wagon. Series II 51 53 20 - Lighting
http://trenulete.info/vagonul-de-calatori-cls-ii-seria-51-53-20-% E2% 80% 93-lighting /
What is the second coach from Tillig Romanian, Series 51 53, he received enlightenment in all departments, plus the final lamp at one end.
For lamps end, the intervention was somewhat more difficult because of construction, the wagon was not equipped with prisms (light guides) and that the holes in the frame lights, which lowers the note manufacturer for negligence. Drilling procedure must be executed with great precision, in steps, starting with very small spiral (0.5) and continuing up to the maximum permitted frame diameter reflector. It is very important that the initial alignment for the first hole, to be made in principle, very carefully, and using a needle under a microscope for scoring. It is also important that the drill be quality, without batting in madrina (... which does not possess, but pierce the hand, throwing the first spiral in a spiral trap, which rotate at hand, my car Drill is one that do not allow such a thing) ... Because of the wagon body molding material is white, slightly transparent, the inside wall, right headlight, and I applied paint negra Revell have also done inside the frame headlamp.
I used two lamps for the final SMD LED, in series between them and then in series with a resistor of 1.2 k For stability, they call a capacitor coupled in parallel with the 1000micro/25 volts. SMD's are soldered directly onto the wagon chassis, right headlight charged holes. Because I did not hole the size of transparent prisms, headlight lens is made of glue ... Revell, poured carefully into those holes, I glued back after temporary waxed paper tape. After drying and hardening the adhesive, the lights have got a touch of realism. I think that is better suited to the manufacture of molded lenses, the material used in water to emulate the scale models.
On rigleta lighting, we separated immediately after leaving the bridge rectifier, two routes, one for lighting compartments, one for lamps and final. At each have stabilized the same light with one capacitor mounted beside each toilet cubicles. All rigleta is one piece, removable, no seams in contact with the wagon, so that any intervention should take place without much effort. To illuminate the compartments were used neon white SMD LEDs, in parallel with each other and in series with a resistor of 820 ohms, so that the illumination parameters fuctioneze in both analog and in digital.
