Автор Тема: Prognosis H0 model railroad - "The town from the dining room"  (Прочетена 473043 пъти)
760mm
« Отговор #360 -: 13 Февруари 2010, 12:42:40 »
Amazing work as always! I also like the passenger train pulled by the BR290 :)
prognosis
« Отговор #361 -: 18 Февруари 2010, 15:27:22 »
Diorama in Slobozia, Town of living February 16. 2010
Town of living as shown him in on February 16, 2010. Diorama in Slobozia with its new enhancements, lighting poles based on LED zeXstar with Bondarul VT 135-062, 20-2007 ER diesel locomotives and 110 BR 226 from Roco. It also notice the engine operation without reproach H0 made me switch based on miniservo, with realistic movement of those translations.
http://trenulete.info/diorama-de-la-slobozia-orasul-din-sufragerie-16-feb-2010/
prognosis
« Отговор #362 -: 20 Февруари 2010, 22:49:24 »
E103 H0 Roco - rebuilding and lights
I recently came into possession of a locomotive that I wanted it very much. E103 produced by Roco in 1974, as shown in a label pasted inside body. Situated in a sorry state of decay, dirty, with broken circuit boards, exfoliate and filled with unsightly wires subtle, full of misery and no one tapon. The effect was instant when I spread it. Nor can I imagine I'll get your.
After I did a piece, we clean it thoroughly with alcohol and I skimmed it with Axion. The tiles around I copied and I fully restored just after the original, only minor modifications we made. More specifically, instead of diodes which powered lights, we installed new lighting resistances necessary. We used SMD LEDs from zeXstar course. For white light, I glued joined in parallel, in 90-degree angle, two LEDs fueled by a resistance of 1100 ohms. For red light lamp with a serial I 920 ohm resistor.
http://trenulete.info/e103-h0-roco-reconditionare-si-lumini/
http://www.youtube.com/watch?v=y9pQFFEiBQQ
760mm
« Отговор #363 -: 21 Февруари 2010, 16:02:08 »
What a great loco made by Roco so many years ago! I'm happy that you've gotten a loc that you wanted very much - the feeling is always great! Good job!
prognosis
« Отговор #364 -: 28 Февруари 2010, 20:52:13 »
Diorama in Slobozia on February 28, 2010
Town of living photographed and filmed by a camera lens can outperform mine. As in pictures and in video can be seen running locomotives is 10 and Dan's e140 Thin Client from Satu Mare, after having gained SMD LED lights, beautiful and elegant E103 and modified BR110 http://trenulete.info/diorama-de-la-slobozia-in-28-feb-2010/
prognosis
« Отговор #365 -: 18 Март 2010, 08:03:42 »
Steam Locomotive BR 38 Liliput
An old locomotive, the '70s generation made the metal chassis. The supply of antique, with the pick voltage polarity by a boiler and the wheels of one polarity on the tender wheels, makes it difficult for the automatic application diorama, but put in jeopardy and statutes for digitization by commissioning short blocks supply. I changed the kind of food, applying a contact strip on the boiler, on the wheels alone that now collect and voltage on the hand by three locomotives Loti ... When we split tender "work" for collecting blood between the two Boghe equally by a trick. I cut metal greutattea they reach the current in the screws and I boghielor isolated parts between them. Both polarities have found continuity through power cables from the traction wheels of the accommodation which now collects on both sides. In addition, we added to the collection curectului and wagons had with its two axles, as now also contribute to a smooth power.
After tying all the wires, we have created supply network between tender and boiler. Tractor had a broken shoulder attachments. How it was dynamic ntimoniu difficult soldering maia les that break was very spot where a hole filenatata facilitate the capture of the chassis, changed entirely with the engine in the same generation t, kept for "who knows what" the stores depot PanArin. That means it's good to keep ...
For lighting I used warm white LEDs from the dipped zexstar point lokomotivei and red LEDs to HGD, the lanterns of the tender. They are fueled by = a diode bridge rectifier and one serial resistor with 820 ohms to 920 ohms to front headlights and the final tender.
http://trenulete.info/locomotiva-cu-aburi-br-38-liliput/
760mm
« Отговор #366 -: 18 Март 2010, 14:31:15 »
 :good:
prognosis
« Отговор #367 -: 19 Март 2010, 12:16:00 »
LED lights on an American loko from Mehano hobby
An American loko with ... fashion! http://trenulete.info/o-americana-mai-cu-fason/
We all know how frustrating it is sometimes when we run Mechanical toys, the range of hobbies, from the lighting leaves much to be desired. Such an American driver, was transferred from the Depot Ploiesti for assistance on PanArin workshops. Engineers and craftsmen of Blumenberg have studied the problem and found solutions to remedy this shortcoming. Comparing different picture of the locomotive original location was decided according to the original position lights.
Since the first trial, it appeared that the ingenuity of craftsmen from the depot PanArin is flawless. The lights worked properly and effectively in both directions, giving a special note of a locomotive rather Fada without lights ... And as evidence of natural routes Blumenberg, massive U.S. prepares to leave for the depot CFSbingu Ploiesti, which will take bread from Sunday.
« Отговор #368 -: 19 Март 2010, 14:24:38 »
Like your sense of humor Prognosis  :good:
prognosis
« Отговор #369 -: 27 Март 2010, 08:38:06 »
MSTS trams Slobozia 03-27-2010
http://trenulete.info/msts-trams-slobozia-03-27-2010/
I have continued work on what route would be a polygon, for testing of future implementations of equipment made by me for Constanta route. At this time we managed to do so I use two different types of textures for lines with a cubic stone of the city's tram lines, and with a classic sleepers for railway lines which intersect tram routes in the area of three barrier level crossings.
As mentioned before, and this route is the fruit of my imagination and passion for the trams. I was criticized for infringing on some blogs reality in two routes mine. I said it and repeat.
1. My routes are semi-imaginary.
2. My passion is for trams, (so who wants to make one bus bus routes that are not specific MSTS ...)
3. I never NEVER proposed that these routes to respect the reality of a hundred percent ...
As such, what we have created remains as we created, improvements are supposed to be applied on this structure and not another. For example, the route Slobozia, I imagined a depot close to the train depot in Railway Station Slobozia Veche ...
I need to tell you that I work on the imaginary ryte on MSTS becouse in the last time, my healt condition is badly and I need to work something instead to cry on my fate. So I work on computer rutes... The work on Diorama de la Slobozia, is out of my healt condition for the moment.
Maktub
« Отговор #370 -: 28 Март 2010, 00:33:25 »
It looks nice, Prognosis. I admire your work, even if I comment rarely, and I really hope you will be able to continue soon also with the diorama.
760mm
« Отговор #371 -: 30 Март 2010, 15:18:16 »
I really like your work Prognosis! It's great that you are creating something that will ever remain! I really hope and in a way do believe that your condition shall get better and that you'll be able to continue your work on the diorama as well soon.
prognosis
« Отговор #372 -: 22 Април 2010, 20:39:31 »
Romanian storied wagon - LED lighting
Romanian storied wagon belonging Railways Sbingu Ploiesti, gave me the patience and ingenuity. Quite complex in this paper two floors to be illuminated as separate but required a serious time of thinking, for developing and designing a plan designed to meet the conditions of land but also flexibility. From the beginning I proposed that wagon to suffer as little change and body parts to leave the chassis without the intervention obviously soldering gun or other special dismounting. Solution found present in the material below. http://trenulete.info/vagonul-etajat-romanesc-iluminare-pe-led-uri/
« Последна редакция: 22 Април 2010, 20:41:14 от prognosis »
prognosis
« Отговор #373 -: 29 Април 2010, 18:48:30 »
Ladder access to railway workers
Since maintenance work on the railroad near the town Blumenberg, in the lower zone, requiring rapid intervention handicraftsmen railway, which were forced to bypass a few hundred meters and then travel along the railway in situations of uncertainty, engineers PanArin FF ordered the construction of stairs for easy access to the railway station located somewhere in the neighborhood below. After the necessary measurements, workers began making and fitting of such ladders.
http://trenulete.info/scara-acces-pentru-lucratorii-feroviari/
prognosis
« Отговор #374 -: 30 Април 2010, 18:18:45 »
April 30, 2010
Pedestrian access works at the scale continued today. Concerned about the safety of citizens of Blumenberg, FF leadership had PanArin completion before May 1 workers' work, which has passionate workers (especially as they were promised the first set) and before dusk, after the chief engineer verified paper It was put into use for the happiness of citizens will not have to bypass long distance.
Here's how it evolved in images and video works:
Around the great celebration of May 1, FF PanArin reports beloved leader proposed implementation plans to date. The depot PanArin recently arrived for surgery, three rail transportation from the Depot HP Barlad. One is a nice V135 already has befriended drone in Slobozia. Automotorul is very well maintained, old but perfectly functional, PIKO product of years of glory. PanArin in yards will bring improvements on the LED lighting issues.
