Автор Тема: Prognosis H0 model railroad - "The town from the dining room"  (Прочетена 473026 пъти)
prognosis
« Отговор #375 -: 03 Май 2010, 19:20:42 »
Traveling by train from Slobozia at Fetesti
May 3rd day meant to me an opportunity to make a personal journey by train from Slobozia at Fetesti. Obviously I have not missed the opportunity to make the reporter and photographer tried to capture as many images in your route. We made about 90 pictures that I captured from different railway vehicles and equipment to railway stations. Cantons abandoned, locomotives in various color schemes, even antiques besides Fetesti depot, which stood near a steamy hour in which I climbed to the despair of a railway worker full of coolness, that I shouted a few times . Old lady who is resting in the foliage of trees after they beat probably far and wide roads of iron. How many do not know much about nor dumneaei and some vehicles whose pictures I've posted here, any explanation of the connoisseurs will be welcomed and will post them in the right place if readers will dare to send them ...
Pray with all my heart not to be upset because I did not put on any forum or blog where memru, detailed history and photos, but travel fatigue only allowed to insert the few thousand rows. Desire but rather how to share my experience, I determined to try to bring the site today, hoping that tomorrow I will write something more about this trip. Till then let dozens of pictures to speak for me. Thank you!
http://trenulete.info/calatoria-cu-trenul-de-la-slobozia-la-fetesti/
prognosis
« Отговор #376 -: 05 Май 2010, 17:28:26 »
VT 135 PIKO - LED lights
VT 135 PIKO Automotorul arrived in Botosani to install LED lights is ready to go to HP Botosani depot. For lighting I used two-color LED red-yellow pole at zeXstar. First I removed the old lighting becuri.Am had in mind a simple assembly that allows trapped wagon without intervention and without soldering gun hanging electrical wires between the body and chassis. The work was divided into two distinct fronts.
1. Blood collection
2. Body lights
http://trenulete.info/vt-135-piko-lumini-pe-led-uri/
prognosis
« Отговор #377 -: 07 Май 2010, 08:06:24 »
Roco BR 218 - LED illumination http://trenulete.info/br-218-roco-iluminare-pe-led-uri/
Locomotive BR 218 from Roco,with the decoder built, was sent from Depot Sbingu Ploiesti for substantial changes. The owner was unhappy with the light origional quality, yellow LED on the lighthouse and the center position, the lack of red lights and especially in this huge and hideous space prisms of what ought to be the cabin, so the default lack cab. Clearly still a work in two fronts. First I removed the prisms (light guides) and we extracted the original headlamp masks.
1. Making lighting
2. Making cabin
I used the new LED dots of 1.8 mm, white-hot for the light and all LED lights point of 1.8 mm for red positions.
I used a cab to achieve Forex special, 1.2 mm thick. It has a yellow color front and the material is black, which is why I chose this forex, because such residual light is prevented from breaking into the cabin lights.
« Последна редакция: 07 Май 2010, 08:08:50 от prognosis »
prognosis
« Отговор #378 -: 08 Май 2010, 20:54:33 »
PIKO BR 185 Connex - LED lighting
Another series of locomotive depot sent from HP and it is Botosani Connex to PIKO BR 185516-2. Arrival in the depot PanArin reason is the change of light bulbs to light emitting diodes.
For this we proceeded to build circuit board distribution box model by the original light guide. I used LED 1.8 mm from the point ...., They have installed after diagram on the site, and the fact the one used in locomotive BR 254 Arco in Ploiesti only in this case I tied each group separately (each cabin) each serially connected with a 820 ohm resistor.
Each plate are glued each five LEDs. Three white and two red parallel alongside each other, but antiparalel with whites. Unfortunately, after a small misunderstanding between me and windosu 'my initial pictures suddenly disappeared from the card, for which, full of gratitude to the RE microsoft, I loosened the locomotive and made other pictures, which are not and as explicit as they were first developed.
Detalii si imagini http://trenulete.info/br-185-connex-piko-iluminare-pe-led-uri/
prognosis
« Отговор #379 -: 09 Май 2010, 13:09:59 »
Roco Locomotive OBB Rh 1142 - improvements
HB depot from Satu Mare, this beautiful locomotive produced by Roco, was sent to Slobozia for installing LED lights on. A model very well done, with many details and multiple accessories. After a full day to painstakingly fit tiny accessories, struts, wipers, electrical outlets, air ducts and even tustucul water spraying on the windshield, I switched to a plan to shift from bulbs to LED sites.
Was more difficult to realize a process by which light can apply this system for locomotive has a guidance system based on light curves, kinda like the BR 218 Roco, the Strategic bypass cab and ends in the right bulb angle of 90 degrees at the end of the prism, the lighthouse at the central front for headlights of position.
For this requirement, we stuck together, the two SMD LEDs Zextar, white-hot. Splice was made to bring in parallel angle of 90 degrees, two LEDs, one for the central lamp and one for position.
Connecting the motherboard I did in the rail supply points, folosid for a red light 1k resistor serially connected with an LED and 820 ohm resistor serially connected with two warm white LED (glued in parallel because they need something more current to be switched). For this type of LED superflux incorporated and one reverse protection diode load (factory, which is particularly effective for protecting the LED), has to fill each group separately by each resistance as I explained above. These LEDs do not allow linking to antiparalel, as shall soon with diode protection.
We highly recommend this type of SMD LED superfulx zeXstar trading at a price without competition, the big advantage is that the building have a reverse voltage protection diode.
Detalii si imagini http://trenulete.info/locomotiva-rh-1142-obb-roco-imbunatatiri/
prognosis
« Отговор #380 -: 15 Май 2010, 20:26:41 »
Line 102 Constanta MSTS Trams
This weekend I tried placing the asphalt in what's left of line 102 nesfaltat Constanta route. Before that I changed the texture of some types of line so far from Constanta can see two types of texture line. One classical, the other with dirt and asphalt.
We also continued to aggravate the elements elimininand path optimization route by merging multiple objects into one. I finally created a sufficiently complex task that line, which I test my real traffic route by crossing with other lines from Constanta.
102 line video presentation http://trenulete.info/linia-102-msts-trams-constanta/
prognosis
« Отговор #381 -: 05 Юни 2010, 21:02:10 »
Power Line 44 - Gate 2
Constantly enriched route this weekend with another route completed. Line 44 of the Energy Gate 2 port and back. Already his work very hard and difficult work remains my time only on weekends. Two routes would remain, the belt line and a line of Mamaia. I do not know when and if I manage to finish this route, but I do not lose hope. I invite you to watch a small movie with this route in the state where they are. Vehicles are put animated characters and some vehicles with parking. Probably next week because tomorrow I want to dedicate and dioramas that I kinda neglected lately. Expect criticism and suggestions on my site!
. I hope my sickness leave time to finish my route and then go quiet when meeting eternity.
http://trenulete.info/linia-44-energia-poarta-2/
prognosis
« Отговор #382 -: 18 Юни 2010, 20:01:10 »
Trolleybuses in Slobozia
http://trenulete.info/troleibuze-la-slobozia/
Considering the current global economic crisis, Blumenberg mayor decided by unanimous vote in the City Council, the introduction of electrified urban transportation. Proposed measure is designed to bring significant savings to the local budget but also to promote an urban environment, clean town of Living. In this strategy, the city has purchased an initial batch Blumenberg two trolleys, made in Switzerland by means of just and supportive Company Silviu HP Botosani. Trolleys have been temporarily parked in the yard IJTL Blumenberg and engineers PanArin were called to design and implement Diorama in Slobozia, entire plant in record time required to implement electrification electrified urban transport in the city Blumenberg. Journalists present at the scene were captured when trolley cars were downloaded from the special and were deposited on the main street, Boulevard prognosis, to be towed to the garage. The event was attended by many personalities of the city and were invited mayors from neighboring towns. Unfortunately, the mayor of Slobozia was protected from public exposure after the last event of the Kaufland where he was cruelly humiliated by three old women and a gypsy, who threw red imported into poisons Slobozia mustaciosul unbearable that infected water.
prognosis
« Отговор #383 -: 20 Юни 2010, 13:44:16 »
Br 95 PIKO - lighting improvements and
http://trenulete.info/br-95-piko-imbunatatiri-si-iluminat/
Just arrived in Botosani, old lady in the picture, a copy of my Duchess, the PIKO model developed in the years of glory came in the depot for interventions PanArin circulation system and lighting. Followed the design and modification of front lighting system. It is present in a combination plate textolit-bulb-socket-weight metal tension spring reception. I decided to use as much of the original system so that changes can be used in keeping with the practical system, mobile and easily made later. Thus, we have reproduced textolit plate circuit board with one side coated.
prognosis
« Отговор #384 -: 08 Юли 2010, 17:00:52 »
Diorama de la Slobozia in ziarul ADEVARUL de seara
http://trenulete.info/diorama-de-la-slobozia-in-ziarul-adevarul-de-seara/
prognosis
« Отговор #385 -: 09 Юли 2010, 09:34:25 »
Liliput BR 38 running on the diorama from Satu Mare
Old lady in the picture, a beautiful Liliput BR 38 made the '80s, has been tested successfully in Slobozia diorama came well after the workshops PanArin and then sent to Satu Mare, which will run on diorama of Dan Committee diorama under construction and will be, in my opinion, the largest and most complex diorama of an amateur home worked. Images on the evolution of the dioramas you can see here: Diorama de la Satu Mare
prognosis
« Отговор #386 -: 09 Юли 2010, 15:37:49 »
July 9, 2010 Town of living
 http://trenulete.info/orasul-din-sufragerie-9-iulie-2010/
Although in the last two months I have not posted much about the evolution of dioramas, here gives me a window during a moment of respite, which he will devote dioramas befitting a modeller who loves his creation. The images and movie below will highlight new works from PanArin workshops, an old steam Duchess in Botosani, which I installed modern LED lights on a locomotive zeXstar and Lima, which had defective lack of a correct angle of boghielor move horizontally, so it does not run properly on toy diorama relief. The slopes, curves and ramps, the car remains practically suspended and salt lines. I corrected this defect by amending metal chassis. He traveled to Cluj just underneath where it was milled, after my drawings, so boghiele to move horizontally, up and down, sideways towards the central axis, depending on the bias lines.
Otherwise, we continued to mount a protective fence in front of the dioramas, along the outer liniiei and intend that the next step to realize the power poles for firobuze (trolley).
Here is the movie made today July 9, 2010. (Sorry for the comment tag from the video I said July 6 ...)
http://www.youtube.com/watch?v=dGFFO7ynnbw
« Последна редакция: 09 Юли 2010, 15:41:40 от prognosis »
prognosis
« Отговор #387 -: 10 Юли 2010, 08:26:09 »
I continued work PIKO 95 Br - and lighting improvements
http://trenulete.info/br-95-piko-old-model-imbunatatiri/] http://trenulete.info/br-95-piko-old-model-imbunatatiri/
 started some time ago and described here with tender light. For starters I made contact tab no existing model. I used copper sheet elastic band made from Marius (minitehnicus) I made a replica of the existing slide.
I made a tender to illuminate common white-red lamp in a warm white LED from zeXstar and a red SMD zeXstar all of which I glued directly to the legs of the LED back-polarity so that the power in sense red light .... ... and the reverse polarity turns white.
Here are a movie with tests PanArin Workshops
http://www.youtube.com/user/PR0GN0SIS#p/a/u/1/TR4I2zvnslk
prognosis
« Отговор #388 -: 11 Юли 2010, 14:06:21 »
Br 130 Ludmila (model Hrushca) - Improvements
http://trenulete.info/br-130-ludmila-model-hrushca-imbunatatiri/
Locomotive BR 130, Ludmila known in the version produced by Hrushca years ago, arrived in just workshops PanArin from Satu Mare for improvement. The model is built by the old method, based on the chassis plate strip finger ends with plastic parts where they are prisms and lamps for lighting. Motorization is one bogie and even power supply is only on the bogie, the inert having no collection system. That is quite annoying by frequent interruptions in supply and will costitui second phase of improvements PanArin workshops. For now, I opened and cleaned the engine that was able Janice, full of dust and hair. Traction is provided only for the two ends of the axles of the bogie, but because it is worm shaft, I'm going to apply driving force and the middle axle.
The first operation, after calling the engine running at normal parameters, was to transform the lighting bulbs, LED warm white. We studied the location of lights and disappointing first impression was that this model, separate farurrile red light can not be used for lighting deoare line is located along the outer wall and a hole pierced is excluded. To ensure we still red brake lights to white lights used only for lenses.
prognosis
« Отговор #389 -: 13 Юли 2010, 15:36:13 »
AB 216 Mehano - improvements
http://trenulete.info/br-216-mehano-imbunatatiri/
Arrived more than a year ago in PanArin Depot, locomotive BR 216 produced by the range Mehano Hobby, was finally scheduled for an overhaul Kapital, during which the lighting was changed to red and white lights depending direction of travel. Locomotive is a pretentious, but occupy a place in my heart modeller, its history is great. Finally she got on my hands with its passenger cars in the set Mehano.
Wheel drive car is only two axles, one on each bogie. The car was equipped with SMD LED lighting on yellow and former owner wanted to change it to red lights. Lack of skill or tools and the experience led to damage by drilling inconsistent mask for red lights and disappointment owner who gave it. Initially I wanted to purchase 218 BR masks but they proved to differ slightly. Finally I decided to fix it and on it. First I fixed masks. I dropped the lighter gray plastic melted in the holes after finishing grinding unbalanced we re correct drilling headlights.
