Автор Тема: Prognosis H0 model railroad - "The town from the dining room"  (Прочетена 473013 пъти)
prognosis
« Отговор #390 -: 18 Юли 2010, 22:38:25 »
Black Anna 0-2-0 tank loco
http://trenulete.info/black-anna-0-2-0-tank-loco/
Received from more than one day in decomposed state from a friend abroad, I found this car on the net to be christened "Black Anna 0-2-0 tank loco. There was a time when I searched on the net pictures of her to know what it looks like pieces are missing. Machine does not have pistons boxes, lights, couplers and buffers. Miniature engine was still intact but without coal. In peroada why I rebuilt the engine and collection system after a short test model came into the park for an appointment to repair cold. After a while, Razvan friend request, he went to the locomotive to be turned into something else sacara TT. After another period, she has been requested by another friend of Braila in love with her is a picture that accidentally occur. Razvan but lost and only a few days ago to found an abandoned one of his boxes. Toy came back to me and how not even know how to give the buddy you wanted, I decided now it's time to bring back a life. So after I found some pictures on the net, I started to repair them.
In the first test was performed excellent toy. Tomorrow painting boxes next piston and rebuilding the roof and chimney. Then other small details after ispiratia pictures and even purchased a lighting system thinking. The problem is that metal chassis configuration is just the limit holes Devid lamps back and so difficult to assemble the lights but I will find solution.
Iata si un mic film cu evolutia in probe a Micutei Black ANNA:
http://www.youtube.com/watch?v=mou6lAkhmA8
prognosis
« Отговор #391 -: 19 Юли 2010, 14:33:20 »
Today we continued work on this little hazy.
Using 1.2 mm thick ABS have made the roof. Webs are made from strips of cardboard 0.5 mm thick. Residue on the other locomotives have completed parts accessories missing. With connection to air hoses, air tank is made of 5mm plastic bar on the left houses kits ... The remaining couplings Fleischmann model faces to another, and I have reunited couplers locomotive made its backing of the front. A tip pen and a piece of mine I made the chimney (reinforced inside with a piece of cake, which remained in place nerupt fall fest on model). I then painted gloss black (because I currently black mat) parts made with red boxes and pistons and chassis where the pieces were reunited ... I put no standard buffers and that 's cars PIKO. The car is ready to run the diorama ... after the paint dries!
prognosis
« Отговор #392 -: 19 Юли 2010, 20:08:39 »
It was solved!
After the first evidence on the diorama I'm not convinced Flaschmann best original couplers. The curves recline on swabs and immediately derailed wagon. Consequently year and I loosened and rebuilt locomotive couplers. In fact I cut the hook from the original joint and combined them with the hook from the hook PIKO changed. A couple reziltat a more flexible and more stable.
Here http://www.youtube.com/watch?v=LPunTh4V-ho movie diorama tests
 The only problem is that the barrier is interrupted supply and car stops. I have this problem before and two axle locomotives which lead me to do something grinding area barrier. Otherwise the car behaves very well in a scrap locomotive became something living and very pleasant to look at the diorama in operation. Follow the lighting design and development.
prognosis
« Отговор #393 -: 22 Юли 2010, 18:45:08 »
Closed wagon axle, Roco 45941 - Electric Final
http://trenulete.info/vagon-inchis-pe-osii-roco-ho-lampa-finala/
Arrived in Ploiesti for the final wagon lamp assembly was scheduled today to PanArin workshops. The paper began by making contact points. I used elastic copper plate used to shield box tv tuner or radio, fixed on 3mm thick strip of ABS. Rzbate wire through the floor behind the plate painted with black ABS to lose the background.
Inside I used a bridge rectifier and a capacitor 1000μF/25 volts,
fixed in a slot that I cut it in teflon weight so as not to upset the wagon.
Resistance is 980 Ω in series with an LED point of 1.8 mm diameter ɸ lens cap lamp mounted perste I made forex 1 mm thick and painted with glossy black Revel
760mm
« Отговор #394 -: 22 Юли 2010, 22:35:28 »
Thats great! I always enjoy the updates from your layout in beautiful Slobozia!
prognosis
« Отговор #395 -: 24 Юли 2010, 11:04:45 »
New challenges in workshops PanArin
http://trenulete.info/atelierele-panarin-programari/
After a year, I received a trenulist believe in Onesti, a set of two wagons Mehano type Thalys, whose owner has broken couplers and you no longer use and do not want them repair. Lately I beat all going to do something with it. How I locomotoarele from this set, I thought maybe trying to make a frame units, modifying the front (end) so that somehow resemble an outdoor underground. Motorizand probably one bogie.
What do you say? Is it worth?
May I then steam on a chassis that we identified as belonging to AB 86. I'll try for the first time to make a locomotive from the chassis. That gives challenge. It remains to find a locomotive BR 86 and plans to go to work ... Does anyone have plans to AB 86?
prognosis
« Отговор #396 -: 24 Юли 2010, 18:48:31 »
Wagon platform - PIKO -
http://trenulete.info/vagon-platforma-piko/
Arrived in Botosani, wagon axle platform from PIKO entered PanArin workshops for the manufacture of simple protective lattice. Engineers have used forex (ABS) 1.2 mm thick white that I have polished to a thickness of 0.8 mm, after which they carved and cut bumpers. Then, the gauge has been traced edges (hardener), and after the first test, the bars were removed and painted with acrylic Revell. After drying, the bars were mounted in bearings and their car is ready to transport various materials.
prognosis
« Отговор #397 -: 26 Юли 2010, 18:23:29 »
The idea of creating a model from scratch gives me no peace for a few days. I documented on both DU 77, and the Czech automotorul, M131, which I find very interesting. I started gathering the necessary documentation and parts, but until then I decided that using some PIKO vintage cars, cars with no future in Slobozia Diorama, to create (yes my hand to what they say) a railcar conception of its own, somewhat similar to M131. As there is enough documentation regarding the achievement of this model, we decided to practice on the PIKO model, a toy rather poorly done and even ugly in some respects. I wanted to do a job not too fancy, something simple and easily made to understand what it means creating a new model.
 I decided to call my model AP 020-01 (automotive prognosis) ... http://trenulete.info/automotorul-ap-020-01/
Here http://www.youtube.com/watch?v=5-klzKTAtR0 motoring test movie
prognosis
« Отговор #398 -: 30 Юли 2010, 16:53:10 »
I continued this work with imaginary change the transmission and engine. I finally decided to leave on a single axle traction, as has the original M131 or 905 Malaxa that according to tests, the model does not need to have traction on both axles, the effort is minimal and can suffice for the tractor trailer on the slopes dioramas even two cars. Again, a design model is imaginary, I like to do that exercise and training in order to achieve a set pattern, as would be M131 or later even DU77.
Evolution works on this model imaginary http://trenulete.info/automotorul-ap-020-01-partea-a-doua/
http://Http://www.youtube.com/watch?v=OxAoe1wUOBY film evolution works
prognosis
« Отговор #399 -: 03 Август 2010, 19:26:49 »
AP Automotorul 020-01 (Part Three)
http://trenulete.info/automotorul-ap-020-01-partea-a-treia/
AP 020-01 automotorul work to prognosis continued with body recovery. I removed the old windows and have good clean soldering hideous place. I repainted the wagon box with airbrushed yellow, a color picture Fada come to change all the original PIKO wagon. Should inquire about how to make a decal that somehow burn the wagon. If you find the solution you use print on transparent self-adhesive sheet. I've rebuilt the windows transparent acetofan left on the buildings. I started realizing I mounted lighting and track lights in the car but the heat wave today, and plan to go to Bucharest today, I have slowed down this process, which certainly will continue tomorrow.
Mail multe imagini: http://trenulete.info/automotorul-ap-020-01-partea-a-treia/
Inca un filmulet: http://www.youtube.com/watch?v=MNjsE_9EE08
prognosis
« Отговор #400 -: 08 Август 2010, 15:31:41 »
The heat wave this week, I worked a little on this imaginary car. However we managed to advance work on time so it only remains for the interior furnishings, including floor. I postponed this goal for a neighbor willing to wait to bring my plate 2 mm thick sheet, which will aggravate the wagons and furniture over which you work.
VAGON Trailer
For wagon wheels, I planted underneath a bridge that we redressed current diodes that I brought on board. I finally chose the lamp oldest torch positioned in the middle, as VT automotorul 135-056. I used an LED diode punctifoma of 1.8 mm diameter, positioned on a circuit board and numbered with a 980 ohm resistor placed in the slot below the floor. Identical to another seat on the opposite side I put another 820 ohm resistor that feeds three of the SMD LED ceiling mounted parallel to light immediately at the lowest current. Also under the floor, a seat left open and I put a capacitor 420 to FM light stability. Thus, light and red lamp light ceiling lamps are lit constantly and regardless of the direction of travel.
VAGON TRACTOR
On the wagon tracks made by two plates have in order to have lighting on both ends. For lights we used transparent plastic light round the rest of the windows of houses fitted for diorama. Frame lights and their shirt is made of termocontractil hose. Such prisms are glued worked on wagon chassis so that it is easily removed.
On the circuit board, I glued down the right prisms SMD LED warm white, mounted parallel to each post and each in series with a 980 ohm resistor placed in temples hidden under the floor above-mentioned departments who have sezizat potential and we used to hide strength.
Otherwise we proceed as in wagon wheels ...
Mai multe imagini si explicatii http://trenulete.info/automotorul-ap-020-01-partea-a-patra/
prognosis
« Отговор #401 -: 08 Август 2010, 19:02:39 »
Iata si filmuletul pe care il dedic celui ce fost OMYDEE…. Dumnezeu sa il odihneasca in pace!
http://www.youtube.com/watch?v=G57kZjFRntE
prognosis
« Отговор #402 -: 13 Август 2010, 18:29:16 »
Festival steam locomotives in Slobozia
Town of living is higher today in celebration. Arrived from various parts of the country and in Germany, steam locomotives were gathered for a small performance in Blumenberg station. Have already been known Br 95 (PIKO) depot from HP Botosani, AB 38 (Liliput) and AB 55 G8 (PIKO) in Satu Mare. PanArin the depot was moved to the old exhibition G8 BR 55 (PIKO) izata CFR (40.065), elegant G7 Br55 (PIKO) and already famous Black-Anna.
The exhibition was completed by the Company's new acquisitions PanArin, locomotives arrived just in Germany and will be scheduled for workshops PanArin modifications, repairs and improvements, eventually to participate in a traffic times on Diorama in Slobozia. Series of these old ladies was opened by an ancient Gutzol BR at 64, followed by another lady PIKO's old guard, AEG locomotives BR 56 2906, car accessories in the box and still has not been run before. He arrived a beautiful mini Duchess AB 93 Roco.Piesa resistance to new acquisitions presented in the exhibition was the station Blumenberg an old BR 52.2006, locomotive equipped with a tender as her tender car extended heating , as shown in pictures.
Exposed locomotives have delighted visitors who had the opportunity to see live how to make railway transport after some time. After being reviewed and tesatte on all lines of city living, beautiful iron ladies of the road were withdrawn PanArin workshops for engineers to study them and their program not for various cosmetic operations and improving lighting. All locomotives are in a state of perfect preservation, fully functional, no damage. As the locomotives will be scheduled at the workshop will present a detailed description of each as well as cosmetic operations will be conducted. News to you, and I invite you to admire the collection of steam and will want to Slobozia Enjoy!
http://trenulete.info/festivalul-aburoaselor-la-slobozia/
prognosis
« Отговор #403 -: 17 Август 2010, 14:19:18 »
Steam Locomotive BR 56 PIKO - improvements
PIKO realized in the glory years, surprised me by making this model mainly as a hobby is a model range. And also details numerous bags of accessories. Although they are sealed envelopes in a box in their car seems to have been little used and how. First type the old engine with discoid collector, this one strange symptom. On the reverse is normally round, that is pretty hard on it but went ahead in the polls only to maximum power and locomotive only if the land itself. So it was rolled, with maximum voltage, a light guide proves especially front melted and combined with some of the black wall of the box protection under the locomotive, but on this subject I will return later.
How were held reconditioning works, improvements and LED lighting, more detail and with many pictures here:
http://trenulete.info/locomotiva-cu-aburi-br-56-piko-imbunatatiri/
prognosis
« Отговор #404 -: 18 Август 2010, 15:42:28 »
Ziua aburoaselor
O zi cu locomotive aburoase pe Diorama de la Slobozia… film special!
Facut partial cu telefonul caci intr-o criza de personalitate, camera video refuza sa mai porneasca… http://trenulete.info/ziua-aburoaselor/
