Автор Тема: Prognosis H0 model railroad - "The town from the dining room"  (Прочетена 491608 пъти)
prognosis
« Отговор #420 -: 19 Септември 2010, 20:18:07 »
Home made crane wagon - 4
http://trenulete.info/vagon-macara-home-made---4/
We continued work on crane car. After I made the crane arm and the truck, I cut I made and installed shutters and staircase of Forex 1mm thick steel string guitar no. 3 for railings. I painted the deck properly, shutters, stairs and rest of ingredients using acrylic Revell.
I mounted headlamps moved forward, one at each pole crane cabin.
To support various bars and other trinkets will be mounted at the end, and after connecting the corresponding ballasted electric lights ...
Followed by a series of small things that will complete this first model made for me by a model. I mention that I had listed plans, worked only when measured against the images and photos found on the net. I'm sure I missed many more like I was wrong, but my first attempt is pretty good. I already know what's wrong, I already know what should be done differently and probably the next model will provide more attention to for a more accurate reproduction.
The first workers who have already taken delivery wagon to accommodate him and for specialized tests ...
Iata si filmul evolutiei lucrarilor la acest vagon-macara
http://www.youtube.com/watch?v=utovZ3actqs
« Отговор #421 -: 19 Септември 2010, 20:33:36 »
super :good: :good: :good: :good:
« Отговор #422 -: 19 Септември 2010, 22:25:02 »
 :ok:  :hi: :hi: :hi:
prognosis
« Отговор #423 -: 22 Септември 2010, 18:50:46 »
Home made crane wagon - 5 http://trenulete.info/vagon-macara-home-made-5/
Today we managed to bring the final stage wagon crane began last week. Thus, the platform after we cut the shutters and I mounted the stairs and railings, we continued with the final fitting red lamps, one on each end, positioned on the right. I used LEDs that go through the shutter and red dots are connected in series with a resistor of 980 ohms and turns antiparalel so each depending on the direction of travel. I thought whole circuit positioned beneath the floor, so that model to be able to remove without the intervention of soldering gun. I thought of taking blood from the plate located on the chassis through contact lameme guitar made of rope and attached to another circuit board located under the bridge, thus, bridge into place by pressing them and ensure electrical contact. From the same point and lights are powered lights in the cabin but connected through another resistor and installed as the red.
I redid the first cart that I lost the house and after 4 hours of searching I gave up on him ...
Of forex and I made the hook body. Pulley is made as those on the wheelchair and is one coupling hook them to steam accessories ...
I made all of forex and diesel tank ...
Crane cable is made of three wires bility, twisted healthy and then painted with black permanent marker.
For drums I used pencil and Chinese forex ...
Follow couplings, boxes of tools and accessories for small infumusetarea model. I'm terribly sorry that I have access to technology type sticker lettering but I think somehow peintez yellow on transparent self-adhesive sheet, which is thick and ugly, but after another method of lettering stick but I do not have ...
Before fixing the protective lacquer paint, dirt and I have dull paint here and there in important ... then the car was taken by the City Blumenberg and sent to work in areas where we began replacing underground cable television. Said happy new workers or their utility.
prognosis
« Отговор #424 -: 24 Септември 2010, 09:06:56 »
Vagon macara home made – final
http://trenulete.info/vagon-macara-home-made-final/
Film cu rulajul vagonului macara realizat integral acasa dupa imagini de pe net.
http://www.youtube.com/watch?v=Cru7Xr708g4
prognosis
« Отговор #425 -: 27 Септември 2010, 19:35:50 »
Reconditioning and Improvements
http://trenulete.info/locomotiva-americana-cu-abur-638/
Last week arrived in Constanta weather some steamy forgotten, dismantled and odd. Owner no longer hope to see them going, but the depot PanArin craftsmen began reconditioning action. Although this work is parallel in several workshops at all four antique cars, and I will briefly present each paper in turn, starting with this car on Steam, a U.S. locomotive.
After the first investigation, we found blocking rotor electric motor traction. He had bent the axle and therefore was replaced with a rotor from a Lima locomotive, and height, after minor adjustments were perfectly matched.
Lighthouse Central, received a warm white LED ... The lack of tender shell was reconstructed by using forex ... balustrades lack of various sizes were made from guitar strings and mounted in place ... lighthouse tender received bipolar Bicolor LED yellow / red .... The first tests I discovered that the car is equipped with smoke generator. This song has a reciprocating motion acting on the locomotive. The generator was loaded with about deposits and cabbage and the plunger was blocked connections. After cleaning it works perfectly adequate. Expect arrival corresponding liquid smoke testing.
And after recalibration slide contact and restoring ties, locomotive is given in tests Diorama in Slobozia. The car runs perfectly and is ready to go to depot basis of constant.
Iata si filmul testelor de rulaj cu noul motor precum si iluminarea:
http://www.youtube.com/watch?v=bZ_pofGhIwY
« Отговор #426 -: 27 Септември 2010, 20:59:26 »
 :clapping: :clapping: :clapping: :clapping: :clapping: :clapping:
prognosis
« Отговор #427 -: 02 Октомври 2010, 12:41:28 »
Old Steam Locomotive Piko BR 55 - reconditioning
http://trenulete.info/br-55-old-piko-reconditionare/] http://trenulete.info/br-55-old-piko-reconditionare/
Arrived in the Dobrogea region, it is this engine in a pitiful state. Sparta with so many missing parts of the body and the bielaj, engine failure, but an emotional high for the owner, he entered the locomotive repair Kapital. After I changed to an identical engine but with full bushes and the Power (coal suprtul, springs, etc. ...), I went to the roof restoration. Piss lack of forex and have been made in those places put together. Chitu, sanded and painted. As there are no repair parts for them, I decided to confectionez you can at home, using various materials ...
The buffers were replaced after removing broken by cutting waste. We've assembled the chassis and drill pads in trade, taken from the pharmacy's Rally ...
For rods, the issue is complicated. After studying the problem we chose the most viable solution.
I rebuilt the main rod using ABS. Piston shaft was made of copper wire, wire softer I flattened it off by hitting the cob and in which I practiced for rivet hole of 0.5. Pins are rivets.
For rods to be identical we worked together ... After that I cut and pasted them have properly with cyanoacrylate.
Show more simplistic but at least for the time variant change the locomotive hobby. Follow the reconstruction of other parts of bielaj, lighting installation (which involves the manufacture of lanterns in November - the old ones were lost) ... as described above.
prognosis
« Отговор #428 -: 03 Октомври 2010, 15:43:49 »
DIGI 218 BR - improvements http://trenulete.info/br-218-digi-imbunatatiri/
Roco BR 218 locomotive, equipped with a built-built factory is a good engine and the mechanical traction, but owners know that the lighting is poor. Not to mention the lack of car and light guides by this monster. For such a change came from a locomotive BR 218 Roco Tulcea. Having already an attempt to actively locomotive in Ploiesti, but connected to analog, I started reconfiguring the system of power. Practically everything we redesigned assembly building combining the cabin lighting system. I removed the original LEDs will as their sanctuary to connect the wires to the new boards lighting so that light can be controlled from remote.
So I made the board cab made for the depot model GS Ploiesti. Basically cabin became electrical connections and support for LEDs. On the same plate is connected all LEDs, 820 ohm resistor for red lights, dipped headlights and central position. The latter resistor is connected without because there's already one on the motherboard. Slots connected to the power of the two original yellow LED (deleted). All ansablul is mobile so the cabs can be taken any time off for any inteventii. Nothing is glued on the body, are extracted from the dwelling quarters in that it is working perfectly embodies exactly the inner profile of the body. LEDs ansablul out with the cab without being stuck on car mask. A beautiful car with lights as ready to go to Tulcea to enter the digital mode of operation.
prognosis
« Отговор #429 -: 21 Октомври 2010, 10:45:09 »
Film of a living city, train diorama in Slobozia printed CFR crane built by me, with washer tank wagons and coaches prepared to mark the CFR after coming stickers.
http://trenulete.info/diorama-de-la-slobozia-in-20-oct-2010/
prognosis
« Отговор #430 -: 23 Октомври 2010, 11:00:50 »
Another very nice model but odd and useless mototul, arrived in Constanta for reconditioning. This steam car, built by Roco, is a strange blend between quality and Roco Roco puerile. Metal chassis, well done, with various facilities for mounting accessories implies that the car was done in several ways. The body of highly detailed, beautifully engraved, handcrafted quality plastic and easy to blend and beautiful chassis bielajul contrasts sharply with crude and simplistic, like children ... Piko boiler door shows a hole at the top, there was probably placed a lamp, though it seems such an incongruous location ... Otherwise all the lights are dummy. If the back will be relatively simple to set the lights, the street front are a new challenge, which I hope to cope with any good idea!
For starters we tested the engine and found a Roco engine, 5-pole, closed all the casing, but nonfunctional at the moment. Probably will be removed and cleaned because he would go, but it stutters.
I started restoring the roof after I studied some pictures on the net, using as a matter of working Forex and 0.8 mm, of which I made tracks. Soldering made with cyanoacrylate and Revell matt black acrylic paint.
http://trenulete.info/locomotiva-cu-abur-br-80-roco/
prognosis
« Отговор #431 -: 23 Октомври 2010, 12:20:57 »
Blumenberg Depot - reconditioned trucks
http://trenulete.info/autobaza-blumenberg-camioane-reconditionate/
Another diorama is the stage in life where I have an account reconditioned vehicles Depot Blumenberg.
In a crisis like this, the mayor thought it would be appropriate to acquire The town of reconditioned vehicles. In this respect, were sent PanArin workshops, some truck parts, with precise indication of being refurbished and use the city played. Thus, specialists Blumenberg PanArin workshops, performance managed to equip the city with some vehicles made of pieces from various layouts destroyed and recovered by HO scrappage program ...
760mm
« Отговор #432 -: 23 Октомври 2010, 19:53:28 »
The one with the grass is cute ;)
prognosis
« Отговор #433 -: 25 Октомври 2010, 10:12:50 »
Gondolas for trolleybuses
http://trenulete.info/gondole-pentru-troleibuze/
Saturday I received a visit from a parent with his son, Samuel, aged 11 years, Slobozia, who wanted to see the diorama. Both child and parent, they instantly loved railway modeling. As a result, on Sunday, I practiced teaching skills for the first time after many, many years and this is what came out of little hands trained child.
How had the house in wagons Lima boghie some parts, I decided that we are using them, to do something simple and easy style that is second gondola cars to buses, which also Samuel home. Because his parents were not willing to make public their son inaginea cadet at the Academy of Trenulism PanArin, I will publish only part of the picture, say, those boy made only objects made under my direction in just one day workshop lesson Rail ...
I rebuilt so they are boghiele Screw the bottom of the gondola platform beneath reinforcing them with a disk of 3 mm thickness in forex will raise hollsurubul
The forex I cut 3 mm thick and the lower platform of 1.2 mm ABS I made shutters drawn wagons and I place that we intaritoarelor acetofan made of 0.2 mm thick, from the cover of an agenda
I shortened boghielor couplings and we strengthened with 1.2 mm thick forex
I made the upper platform, gondola floor of forex 1.2 mm thick, which I traced the press as partitions between floor boards, the sides have buffers attached Drill ...
After curing, sanding and gluing corrugated acetofan, I painted cars and they've undergone the screening test and appearance. After proper ballast, with a thin strip of 1 mm thick plate located under the floor, the cars were towed on the diorama and behaved excellently.
Finally, they went to the local depot Sam, who started modeling as road building two rail cars in its first simple lesson. I hope that the young man to pursue and develop their talent is seen as exhibits. 80% of this work was executed to the satisfaction of the little hands of his parents.
prognosis
« Отговор #434 -: 25 Октомври 2010, 19:35:13 »
Automotorul Malaxa DU 77
http://trenulete.info/automotorul-malaxa-du-77/
After several unsuccessful attempts I finally got the board with clippings in possession of 1.2 mm in forex parts for Automotorul Malaxa, all thanks to a good friend, Emmanuel, who cut to pieces bit by me in Corel comic. As such, today we began the offensive on target DU Fall 77
